  3. Replacing ADE-L variables
  • Views 15008
ASICnm
ASICnm over 12 years ago
Hello all,
I have several variables from transistor parameters in my design, and I want to hardcode them, before I start doing the layout. My script makes a copy of original schematics first, and then needs to replace the values assigned to variables in ADE-L window, to all those parameters.
Could someone hint how to read the ADE variables and replace the transistor parameter with their value. I start the script like this:
;; open original schematic
cvId = dbOpenCellViewByType(myLibName myCvName myViewName)
dbCopyCellView(cvId myLibName myCvName newViewName nil nil t)
;; create a new schematic copy
cvId2 = dbOpenCellViewByType(myLibName myCvName newViewName)
 instId=cvId->instances
;; the following might give me length in my PDK:
car(car(instId~>prop~>value))  ;; e.g. get length
;; now pick up ADE variables
Thanks in advance,
  • ASICnm
    Ok, that got solved, just needed to find this function to proceed with the rest.
    (asiGetDesignVarList (asiGetCurrentSession))
    Ofcourse further processing is required.
    As a beginner it is often hard to locate the functions..
