  3. How to avoid *WARNING* HiQTreeTableSelectionOp ...message...
  • Subscribers 150
  • Views 15744
How to avoid *WARNING* HiQTreeTableSelectionOp ...message when use hiTreeTableSelectItems() ?)
Charley Chen
Charley Chen over 12 years ago
Hi All ,
I have a function is to select all items in a tree , so is below
procedure( selectItems()
 listofItems = hiGetTreeItems(treeName)
hiTreeTableSelectItems(form->treeField  listofItems)
);pro
It is  fine (Although it has a little bit slowly than i select 1st item and last item) , But when i re-select any item in tree item ,
It will show *WARNING* HiQTreeTableSelectionOp:: selectionChangedCB: Selection failed .Too many items are selected such
that the logging command exceeds the command buffer size limit. Select few items.
When i select from 1st to the end of the tree item , and then  re-select any item in tree item , It is OK
 I found the doc , but i tried  and can't understand it.
Selection of tree items is logged differently. In previous releases, selecting multiple consecutive tree items was logged with a range of zero-based line numbers. For example:
hiTreeTableSelectItems(form->treeField list('(1 2) ) t)
Now, the format is different. Instead of line numbers, the relative index in a tree is used. For example:
hiTreeTableSelectItems(myForm->myTreeTable '( (mytree 0 3)))
Thank you,
Charley
  • theopaone
    theopaone over 12 years ago
    If you are looking to select all the items in a tree, you can use hiTreeTableSelectAllItems.
    I suspect you have a syntax error in the selection item table.
    The syntax for hiTreeTableSelectItems could be a list of the symbols of the items or it could be a list of lists, ( (treeItem startIndex endIndex) (treeItem2 startIndex2 endIndex2) ... )
    I would probably go with the item symbols.
    Ted
  • Charley Chen
    Hi Ted,
     Thank you for help. It was fixed.
    Charley
  • buddylee
    buddylee over 11 years ago
    Hello, I have a related question. I am getting the same warning message for exceeding the command buffer size, but it occurs when manually selecting too many items in the tree table. Is there a way to adjust the size of the command buffer? Thanks in advance
    Without seeing the code that produces the problem, it's hard to know. I've not actually found any reports of this warning - so not sure what it would be telling you (unless I can see the code).
    Can you post the code? If not, please contact customer support (and ask the AE dealing with it to contact me because I'm interested in understanding the problem).
    Kind Regards,
  • buddylee
    Thanks for your reply.  Unfortunately, I cannot share the code as-is.  But, I do plan to look into it more and if I involve customer support, I will ask them to contact you.  Also, if I figure out a specific cause I will reply here.
    Thanks! Brady
