  3. Copying Cellview problem
  • Views 17912
frasheed
frasheed over 12 years ago
I am writing a short code to create a library and then copy a Cellview from another Library into this new library. The code is :
 p= pwd()
if( dbCreateLib( "myLibrary" p) != "nil"
    then
    cvid = dbOpenCellViewByType("OLD_Lib" "test" "layout" "maskLayout" "r")
    dbCopyCellView(cvid "myLibrary" "test" "layout" nil  nil t)
    dbClose(cvid)
    else
    print("can't")
); if
When I run this code I got many warning  " ddGetObjLib: Was passed an Invalid Id" but my cellview gets copied, When I try to open the copied cellview it says that "The technology Library has no constarint groups that have a Valid layers opr validvias constraint defined.Can oanyone help me why is this so ? Is it bacuse that Libary path is not copied ?
  • frasheed
     Hello, The problem has been solved I forgot to copy the Technology file to the new Library
