  3. creating a browse button to browse directories
  • Replies 7
  • Subscribers 153
  • Views 19615
harishgurram
harishgurram over 12 years ago
How to create  a  button to browse directories. The user can able to select multiple directories, and the output should be of return type list.
Please tell me how to do this.
 Harish.
  • Quek
    Quek over 12 years ago
    Hi Harish
    You can do it as follows:
    a. Create a string field in a form
    b. Create a button field and reference the string field:
          runDir=hiCreateStringField(
             ?name 'runDir
             ?prompt "Run dir"
             ?value "./avSVS"
          ) ;hiCreateStringField
          dirSel = hiCreateFormButton(
             ?name 'dirSel
             ?buttonText "..."
             ?callback "ddsFileBrowseCB(hiGetCurrentForm() 'runDir \"*\" 'directoryOnly)"
          ) ;hiCreateFormButton
    Best regards
    Quek
  • theopaone
    theopaone over 12 years ago
       IC61x includes the hiCreateFileSelectorField which automatically does the things that Quek created with two fields. It includes the same modes as ddsFileBrowseCB. This is example was cut from a program I wrote for a client but the documentation in the UI reference manual is very good.
    Ted
         lmField = list( hiCreateFileSelectorField(
                     ?name '_LayerMapFile
                     ?prompt "Stream Layer Map"
                     ?mode 'existingFile
                     ?value AEgetLayerMap( geGetEditCellView())
                     ?defValue AEgetDefaultLayerMap( geGetEditCellView())
                     ?callback sprintf( nil "AEgetFormCheckFileExists( %s '_LayerMapFile )" formName )
                     ?editable t
            0:(fieldHeight + fieldSpacing) * row++ fieldWidth:fieldHeight promptWidth)
  • harishgurram
    But with this type of button we can not select multiple directories, I mean we can select at a time one directory only. But I need a list which contains all my selected directories. How to do this.
  • theopaone
     You are correct, it only works for a single directory, it can work with multiple files but not multiple directories. You possibly could add a callback which builds a list of directories but maybe Quek's solution is better in this case. I've not used ddsFileBrowseCB.
    Ted
  • skillUser
    skillUser over 12 years ago
    Try this example instead:
    lb = hiCreateListBoxField(?name 'CCStest ?prompt "Select directories"
          ?choices setof(obj getDirFiles(".") isDir(obj)) ?multipleSelect t)
    => listBStruct@0x233fb578
    fm = hiCreateAppForm(?name 'CCStestForm ?formTitle "Multiple dir select"
           ?fields list(list(lb 0:0 400:230 100)))
    => formStruct@0x233fb598
    hiDisplayForm(fm)
    hiFormDone(CCStestForm)  <--- this shows in the CDS.log when the form is done
    hiGetListBoxValue(fm->CCStest)
    => ("test" "rectTest" "cpTest" "copyTest")
    Hopefully you get the idea, use a listbox field with multipleSelect true and then obtain the value of what was selected afterwards.
    Best regards,
    Lawrence.
  • theopaone
    Thanks, Lawrence.
    Neither ddsFileBrowserCB nor hiCreateFileSelectorField allow you to select multiple directories. Maybe file an enhancement CCR on that one?
    Ted
  • saurabh96
    saurabh96 over 5 years ago in reply to skillUser
    Hi Lawrence,
    Suppose from browse button we had to only call .gds or .cdl file and if user select other than these two extension file will not be select.How we can do it using skill in browse button option?
