  3. How to append a label on a rectangle created by dbCreateRect...
  • Replies 7
  • Subscribers 150
  • Views 18366
How to append a label on a rectangle created by dbCreateRect()
DesmondLiu
DesmondLiu over 12 years ago
Hi experts,
     Using dbCreateLabel() could only create the label in cellview but not appended on a object (e.g. rectangle).
 Is there any way that I could append a label on a rectangle (i.e. as a children of a rectangle) created by dbCreateRect() (but not rodCreateRect()) ?
  • skillUser
    skillUser over 12 years ago
    Hi Desmond,
    Add a call to leAttachFig() with the label and rectangle shape database ID's and this will make the label a child of the rectangle. I'm assuming that you are doing this in a layout. Alternatively you should be able to directly update or modify the parent attribute of the parent object's database ID, adding the child ID in a list (since the parent-child relationship can be one-to-many, it is represented as a list).
    Hopefully this answers your question?
    Lawrence.
  • theopaone
    theopaone over 12 years ago
     The parent-child relationship can used in any of the database viewTypes.  You can change a figure's parent but not its children.
    figId~>parent = parentFigId
    Ted
  • DesmondLiu
    Hi Lawrence,
        Thank you, this exactly answered my question.
  • DesmondLiu
    Ted,
        Thank you. I think the key I stuck here is that I don't know I can't change/assign a figure's children so I kept finding a function
    to attach labels on rects.
  • theopaone
     Hi Desmond
    The descriptors for which attributes you can change directly (parent) and which are changed through another attribute (children) are found in the Virtuoso Design Environment SKILL Reference under Database Access.
    rectId = dbCreateRect( ... )
    labelId = dbCreateLabel( ... )
    labelId~>parent = rectId
  • DesmondLiu
    Hi Ted,
         This is a great idea assigning parent-children relation.
    Thank you for your suggestion.
    Wish you a good day.
  • theopaone
    Hi Desmond,
    Your icon is quite appropriate for this discussion. {8^)
    Ted
