  3. How to generate a list of display layers?
  • Views 18733
KokoLiu
KokoLiu over 12 years ago
 I am using cadence virtuoso version IC6.1.5-64b.500.17. I would want to generate a list of layers that is already displaying in my Layout editor window.
 I already know there is a function call leLSWShowLayers(), but I am not using LSW. I am using layer palette. And I can't bring LSW up using leRaiseLSW() because my palette assistants are enabled.
 I can't use the solution in solution 20268008 by using pteRegisterUserSelectionTrigger because my cadence version isn't new enough.
 Please let me know what other ways I can produce a list of displayed layers?
 Thank you.
KokoLiu
  • skillUser
    skillUser over 12 years ago
    Hi KoKo,
    You can get a list of the layers using SKILL, for example:
    lcv = geGetEditCellView()
    => db:0x1a6dea12
    lcv~>lpps~>layerName
    => ("Metal1" "Metal2" "edgeLayer")
    hiGetCurrentWindow()->stopLevel = dbGetMaxHierDepth()-1 ;; I did Shift-F in the layout
    => ("Nwell" "Pimp" "WellBody" "Metal1" "Nimp"
         "allGeoShare" "Cont" "text" "Oxide" "Poly"
    foreach(mapcar lpp lcv~>lpps list(lpp~>layerName lpp~>purpose))
    => (("Nwell" "drawing") ("Pimp" "drawing")
           ("WellBody" "drawing") ("Metal1" "drawing")
           ("Nimp" "drawing") ("allGeoShare" "GeoShare")
           ("Cont" "drawing") ("text" "drawing")
           ("Oxide" "drawing") ("Poly" "drawing")
           ("Metal2" "drawing") ("edgeLayer" "drawing"))
    Hopefully this is what you are looking for?
    Lawrence.
  • KokoLiu
    Hi Lawrence,
     Thank you for your reply, but that wasn't what I am looking for. The skill code you provide will able to get a list of layers that are used in the cell. But I wish to get a list of layers that I set it as visible on the palette.
    Koko
  • skillUser
     Hi Koko,
    Try this instead:
    lays = leGetValidLayerList(techGetTechFile(geGetEditCellView()))
    => (("Oxide" "pin")
         ("Via1" "drawing")
         ("Via2" "drawing")
         ("Metal3" "drawing")
         ("designFlow" "drawing4")
         ("designFlow" "drawing5")
         ("designFlow" "drawing6")
         ("designFlow" "drawing7")
         ("designFlow" "drawing8")
         ("designFlow" "drawing9")
         ("Row" "drawing")
    setof(lv lays leIsLayerVisible(lv))
    => (("Oxide" "pin")
         ("Via1" "drawing")
         ("Via2" "drawing")
         ("Via3" "drawing")
         ("Metal4" "drawing")
         ("Via4" "drawing")
         ("Metal5" "drawing")
         ("Via5" "drawing")
         ("Metal6" "drawing")
         ("Cont" "drawing")
         ("Cont" "pin")
         ("Poly" "drawing")
         ("Nwell" "drawing")
         ("Pwell" "drawing")
         ("Oxide" "drawing")
         ("Nburied" "drawing")
         ("Nimp" "drawing")
         ("Pimp" "drawing")
         ("Bondpad" "drawing")
         ("text" "drawing")
    This should be close enough to (if not exactly) what you are asking.
    Lawrence.
