  3. How to create a nested pcell but still maintain the strecth...
  • Views 16084
How to create a nested pcell but still maintain the strecth handle capacility?
kb how
kb how over 12 years ago
I'm developing a nested pcell which instantaite a native transistor pcell, and add some routing on top of it. But, this will disable the stretch handle that i previously build intransistor.Is there a way i can create a nested pcell and maintain it existing stretch handle capability?
Many thanks
  • theopaone
    theopaone over 12 years ago
     I've never tried this so it is only a guess and I have no access to Virtuoso as I am on holiday.
    Stretch handles are handles on Rod objects, there is no way of creating a floating stretch handle. Stretch handles are in the master so they are one level of the hierarchy down from your design. You would have to duplicate the stretchable objects in the placed parameterized cell in the new master, either as pseudo objects (on non maskable layers) or copies of the the objects themselves and then apply the Rod handles and rodAssignHandleToParameter so when the new master is placed, the handles are available.
    When you create the pcell code, the value of the stretch handle parameter on the placed parameterized pcell is calculated from a parameter on the new master. The value of the parameter on the new master is determined by the stretching of stretch handle in the new master. When the handle is stretched, the new master parameter is calculated and the placed parameterized pcell parameter is updated as the the master is regenerated.
     Ted
  • kb how
    Thanks for the reply.
    This is really useful. I was trying the same way but i just cant find any way to pass the stretch handle on top to bottom instance.
    Appreciate if you have any example.
  • theopaone
     I'm on holiday so I may not get back to this till next week.
    Ted
  • kb how
     Thanks a bunch.
