  3. Help Needed: String to Symbol
  • Views 17960
frasheed
frasheed over 12 years ago
I am reading Librraies and their path and thens storing them in a file. The ouput should look like
Libname /pro/work/libname
Libname1 /pro/work/libname1
Libname2 /pro/work/libname2
My code is :
h = outfile("out.txt" "a")
foreach(lib ddGetLibList()
  fprintf(h "%L /%L\n" stringToSymbol(lib~>name) stringToSymbol(lib~>readPath))
  close(h)
 but I am getting this in output file
 Libname \/pro\/work\/libname
Libname1 \/pro\/work\/libname1
Libname2 \/pro\/work\/libname2
after every special character I am getting a back slash (\), Any hint to remove that ?
  • skillUser
    skillUser over 12 years ago
    Instead of using the "%L" format, try using "%s", and you do not need to use stringToSymbol() either, so the code might read:
      fprintf(h "%s\t%s\n" lib~>name lib~>readPath)
    close(h)
    This should be closer to what you want I think.
    regards,
    Lawrence.
  • frasheed
     Hi Lawrence,
    Thanks! It works :)
