  3. Help: Searching part of string in list
  • Subscribers 150
  • Views 21478
frasheed
frasheed over 12 years ago
 Hey,
Can anyone give me hint to serach part of string in list.
Example:
partName = "newStar"
fullNames = '("oldStarwork" "newStarWork" "loadStar" "halfStarwork")
if  Icheck it with member(partName fullNames) then will return nil but I want "newStarWork" as answer, I read the documenattion there is only member and memq functions are deifned for seraching lists . I looke the function recmatchp but its jist for symbol or strings and I have list (fullNames)
    rexMatchList(partName fullNames)
    If that hadn't have been available, you could have done:
    rexCompile(pattern)
    setof(fullName fullNames rexExecute(fullName))
    But rexMatchList does this for you.
  • frasheed
     Hey Andrew,
    Thanks for the quick help it works. :)
  • frasheed
     Hey Andrew, rexMatchList is working fine for list but rexMatchp is not working properly for some cases. Example:
    I have a layout that has two gates g1 and g2 , and I am writing code to add a new property called "fix" to the instTerms
    so code goes like
     procedure(CCFaddInstPinLabels(@optional (cellView geGetEditCellView()))
    let( (transform pinCenter)
      foreach( inst cellView~>instances
        transform=inst~>transform
        foreach( instTerm inst~>instTerms
         case(instTerm~>name
          (rexMatchp("g" instTerm~>name)
            dbSetq(instTerm "G" fix)
           ); case
      ); foreach instance terminal
      ); foreach instance
    );let
    ); procedure CCFaddInstPinLabels
    but it's not setting up the propert,  the problem is with matching , if I write (rexMatchp("s" instTerm~>name) then its workin fine, because there is only one source and "s" matches with the instTerm~>name.
    Can you please tell me is this method ok ?
  • theopaone
    theopaone over 12 years ago
        case(instTerm~>name
           ); case
    Case is the wrong function to use, try cond. Case evaluates its first argument and then checks for the block designated by the matched string/integer.
    Cond executes each condition (like an if/then/elif/else in other languages) and executes the block for the first condition that returns true.
       cond(
    ;; Fix the g terminals
    ;; fix the s terminals
            dbSetq(instTerm "S" fix)
           ); cond
    And you might want to better qualify your search, what begins with "g" is "^g"
    Ted
  • frasheed
     Hey ted, Thanks for the reply and valuable information :)
