  3. HELP: SKILL code not waiting for calculations
  • Views 15550
frasheed
frasheed over 12 years ago
 Hello All,
I wrote short code to calculate the biggest the value for upper right x y and lowest vale of x y and then do subtraction to get the width and height:
my code is like:
 procedure(math(bBox corner)
let((x y tx ty)
x = car(caar(bBox))
y = cadr(caar(bBox))
 case(corner
  ("lower"
    foreach(s bBox
      tx = caar(s)
      ty = cadar(s)
      if(tx<x
      then
       x=tx
      );if-tx
      if(ty<y
      then
        y=ty
      );if-ty
    );foreach
   result = list(x y)
  );lower
    ("upper"
      foreach(s bBox
        tx = caar(s)
        ty = cadar(s)
        if(tx>x
        then
          x=tx
        );if-tx
        if(ty>y
        then
          y=ty
        );if-ty
      );foreach
     result = list(x y)
    );upper
   return(result)
   );case
  ) ; let
) ; procedure
  ll = math(cellView~>instances~>bBox "lower")
 ur = math(cellView~>instances~>bBox "upper")
w = car(ur) - car(ll)        ;Width
h = cadr(ur) - cadr(ll) ; height
viaParams = list(list("cutWidth" w) list("cutHeight" h) list("originOffset" list(w/2 h/2)))
b_db = dbCreateVia(cellView viaDef ll "R0" viaParams)
This is just part of the code , before this I am converting Schematic to layout then this calculation and then placinga via , so when I run this code then I got warning that
dbCreateStdVia: Zero width and/or height value(s) specified for a via cut
and then error:
dbTransformPoint: Invalid point - nil
What I think that SKILL is code is so fast that it doesn't wait for the conversion of all layouts and move to math function and since there is no layout there so It's not calculating width and height, If I manually creat layout and then just run the part of code where its calculating width and height, then its working fine , even This code is working fine with 1 technology (32nm) but not with 14nm.
 any suggestion on this ?
Thanks!
  • skillUser
    skillUser over 12 years ago
    I think it would be useful to actually include the code section that contains dbTransformPoint since the error is in the arguments passed to that function.  SKILL is single-threaded and statements are processed sequentially in the order written (with a few exceptions, such as code that uses ipcBeginProcess(), hiRegTimer() and UI events are asynchronous).  So you will need to walk through your code in the order it is written.  Providing the actual code segment might allow someone on the forum to provide better help. Also the code to find the width and height of a bounding box can be simplified:
        width  = abs(apply('difference mapcar('car bBox)))
        length = abs(apply('difference mapcar('cadr bBox)))
    You can iterate this over each of the bBoxes and use functions like min and max to locate the largest or smallest X or Y ordinate. Ideally SKILL functions written outside of R&D should use an uppercase prefix to prevent your function clashing with any internally defined functions - some code on the forum uses a CCF prefix, for example, or code written by Cadence Customer Support uses a CCS prefix; this shows the origin of the code in addition to avoiding name clashes.
    Hopefully this helps you.
    Lawrence.
  • frasheed
    Hey Lawrence,
    Thanks for your help , Yeah I was considering the wrong points of bBox
