  3. Help: Creating Rectangle with nano-meter (nm) values
  • Views 14966
frasheed
frasheed over 12 years ago
I wrote a skill code in which I was creating rectangle using skill code:
 rodCreateRect(?name "rec" ?cvId geGetEditCellView() ?layer list("M1" "drw") ?width 5 ?length 5 )
 I was not using any units with width and length but now I want to use nano-meter units and this command is giving warning
*WARNING* rodCreateRect: ?width: zero value not allowed - 0
*WARNING* rodCreateRect: ?length: zero value not allowed - 0
*WARNING* rodCreateRect: command failed
Why is this so ? I am using 32nm technology library.
    So what did you actually use? The numbers for ?width and ?length need to be in UserUnits - so if you do:
    geGetEditCellView()~>userUnits
    it will probably return "micron". If so, 5nm would need to be specified as 0.005 - if you enter it as 5n, it will be below a database unit (see geGetEditCellView()~>DBUPerUU - this will probably be 1000.0 or 2000.0 - that's the number of database units per user unit, so in my case I have 2000 database units per micron - so a resolution of 0.5nm. If I'd entered 5n as the value, that would be treated as 5 femtometres, which is smaller than the database resolution (and a bit tricky to manufacture too!)
