  3. Help with OceanScriptXL output problem
  • Subscribers 150
  • Views 15330
jjang3
jjang3 over 12 years ago
Hi everyone, although this is SKILL thread, I thought oceanScript XL and SKILL are kind of a same thing so I decided to post it on here.
I'm very new at programming with OceanscriptXL and what I wish to do is I have two separate tests in ADE XL running in monte carlo that I wish to have two separate output text files. Therefore I decided to use ocnPrint command to print the values into the respective text files, but the problem is, after the first test, outputs disappear for subsequent tests and I receive following warnings:
load "test3.ocn"
WARNING (OCN-6054): The output '/OUT2' you selected does not exist.  Type outputs() to see the list
        of available outputs or type help('v) for more information on the 'v' command.
WARNING (OCN-6054): The output '/OUT22' you selected does not exist.  Type outputs() to see the list
 Following is my code:
;====================== Set to XL mode =========================================
ocnSetXLMode()
ocnxlProjectDir( "/home/j/jjang3/simulation" )
ocnxlTargetCellView( "Lib" "SRAM" "adexl" )
ocnxlResultsLocation( "" )
ocnxlSimResultsLocation( "" )
;====================== Tests setup ============================================
;---------- Test "Lib:SRAM:1" -------------
ocnxlBeginTest("Lib:SRAM:1")
simulator( 'spectre )
design( "Lib" "SRAM" "schematic")
modelFile(
    '("/home/j/jjang3/models/Librarymodel.scs" "models")
    '("/home/j/jjang3/models/Librarystat.scs" "statistics")
    '("/home/j/jjang3/models/Library.scs" "parameter")
definitionFile(
    "/home/j/jjang3/models/vsrc"
analysis('tran ?stop "10n"  ?save "selected"  )
envOption(
'analysisOrder  list("tran")
selectResult('tran)
saveOption( ?simOutputFormat "psf" )
save( 'v "/VR6T" "/VL6T" )
temp( 27 )
ocnPrint(?output "~/output1.txt" v("/VR6T") v("/VL6T") ?from 1n ?to 1n ?step 1n)
ocnxlOutputSignal( "/VR6T" ?plot t )
ocnxlOutputSignal( "/VL6T" ?plot t )
ocnxlEndTest() ; "Lib:SRAM:1"
;---------- Test "Lib:Model2:1" -------------
ocnxlBeginTest("Lib:Model2:1")
design( "Lib" "Model2" "schematic")
modelFile(
definitionFile(
envOption(
option( 'temp  "90.0"
selectResult('tran)
save( 'v "/OUT2" "/OUT22" )
converge( 'ic "/net018" "0V" )
converge( 'ic "/net017" "1V" )
temp( 90.0 )
ocnPrint(?output "~/output2.txt" v("/OUT2") v("/OUT22") ?from 1n ?to 1n ?step 1n)
ocnxlOutputSignal( "/OUT2" ?plot t )
ocnxlOutputSignal( "/OUT22" ?plot t )
ocnxlEndTest() ; "Lib:Model2:1"
;====================== Sweeps setup ===========================================
;====================== Model Group setup ==========================================
;====================== Corners setup ==========================================
;====================== Job setup ==============================================
ocnxlJobSetup( '(
"blockemail" "1"
"configuretimeout" "300"
"distributionmethod" "Local"
"lingertimeout" "300"
"maxjobs" "1"
"name" "ADE XL Default"
"preemptivestart" "1"
"runtimeout" "-1"
"showerrorwhenretrying" "1"
"showoutputlogerror" "0"
"startmaxjobsimmed" "1"
"starttimeout" "300"
;====================== Disabled items =========================================
;====================== Run Mode Options ======================================
ocnxlMonteCarloOptions( ?mcMethod "all" ?mcNumPoints "2" ?mcNumBins "" ?samplingMode "random" ?mcStopEarly "0" ?mcYieldTarget "99.73" ?mcYieldAlphaLimit "0.05" ?saveAllPlots "1" ?useReference "0" ?donominal "1" ?monteCarloSeed "" ?mcStartingRunNumber "" ?saveProcess "1" ?saveMismatch "0" ?ignoreFlag "0" )
;====================== Starting Point Info ======================================
;====================== Run command ============================================
ocnxlRun( ?mode 'monteCarlo ?nominalCornerEnabled t ?allCornersEnabled t ?allSweepsEnabled t)
ocnxlOutputSummary(?yieldSummary t ?exprSummary nil ?specSummary nil ?detailed nil)
;====================== End XL Mode command ===================================
ocnxlEndXLMode()
I have no clue why outputs suddenly disappear after the first test. Did I mess up on the format of oceanScript XL or is it some other problem? I also tried testing each circuits (SRAM and Model2) separately, and if they are by themselves in the oceanScript XL, it works, but when I try to put those two tests into one oceanScript XL file, output is gone and I have been trying to figure this problem out for a while now and I just cannot figure it out.
In addition, is there any alternatives to ocnPrint? I tried using fprintf command to output, but I must have run() command before fprintf otherwise I cannot get the output on time. However, this also creates a problem because there is no way to do this in monte carlo simulation since run() only executes once. How do you use fprintf on monte carlo simulation on oceanScript XL so that it actually does monte carlo simulation instead of single simulation?
Thank you so much for any kind of helps
 Sincerely,
  • tweeks
    tweeks over 12 years ago
    Sorry, I don't use ocean.
