  3. Bringing shapes up from lower level cells
  • Subscribers 150
  • Views 15984
Michael L
Michael L over 12 years ago
 I am trying to copy a specific set of layers in all lower level cells up to the current level of hierarchy.  My current code is as follows:
info = geGetWindowCellView()
bbox = info~>bBox
all_objects = leSearchHierarchy( info bbox 32 "any shape" nil )
epi_objects = nil
foreach( shape all_objects
   layername = substring( shape~>layerName 1 3 )
   if( layername == "EPI" then
      epi_objects = cons( dbCopyFig( shape info ) epi_objects )
This doesn't work correctly.  It copies each EPI from the lower level cell relatve to it's origin, to the top level relative to it's origin.  That is, they are all shoved down and to the left...  I want the EPI objects to be placed "where they belong", over their hieractical positions.
Can someone please tell me how to fix it?
  • tweeks
    tweeks over 12 years ago
    There are multiple solutions.
    One of them is to use dbGetHierPathTransform() (assuming leSearchHierarchy() returns a hierarchical path like dbGetOverlaps() and friends), then dbConcatTransform() with dbTransformPoint(), dbTransformPointList(), or dbTransformBBox(), depending on what sort of shape it is.
    Another solution is to use the rod* functions, which can name the shapes and give you their transformed coordinates automatically.
    Yet another solution would be to copy the subcells and flatten the copies, deleting what you don't want. :)
  • theopaone
    theopaone over 12 years ago
     dbCopyFig has a third argument, a transform. You can calculate the hierarchy transform and put it into the dbCopyFig call.
    Ted
  • tweeks
    I never noticed that!  That's quite handy.
