  3. Can SKILL++ symbols be unbound?
  • Views 17441
tweeks
tweeks over 12 years ago
In SKILL mode, you can unbind a symbol's value slot by assigning the special symbol unbound to it:
> f = 3
3
> boundp 'f
t
> f = 'unbound
unbound
> f
*Error* toplevel: undefined variable - f
<<< Stack Trace >>>
> boundp 'f
nil
You can also unbind the function slot by putting nil there:
> putd 'f (getd 'car)
primop:car
> fboundp 'f
primop:car
> (f '(1 2 3))
1
> putd 'f nil
nil
> fboundp 'f
nil
> (f '(1 2 3))
*Error* eval: undefined function - f
However, in SKILL++ mode, symbols use the function slot exclusively, so putting nil there is the same as assigning the symbol to nil.  Continuing from the previous example:
> toplevel 'ils
ILS-> f
nil
Is there a way to actually undefine a SKILL++ symbol?  It seems you would need to unintern it from the SKILL oblist and/or remove it from the toplevel environment frame.
    Tom,
    It's slightly tricky - you have to define a SKILL (not SKILL++ function) with the same name, and then putd() the symbol to nil. Since this is an internal implementation detail and not exactly obvious, I've been talking with R&D about providing a macro or syntax form to do this which works in both SKILL and SKILL++ (ILS) modes.
    Here's a macro that I wrote that you can use in the meantime which does the job:
    (defmacro CCFunbind (varName)
      `(if (theEnvironment)
         (inSkill
           ; Bit messy as can't swallow warning from the defun.
           ; The idea is that it defines a function for the variable name
           ; and then sets it to nil afterwards.
           (let ((nullport (outfile "/dev/null")))
             (unwindProtect
               (let ((woport nullport))
                 (defun ,varName () nil)
                 (putd (quote ,varName) nil))
               (close nullport)
         (setq ,varName 'unbound)))
    With this, you can just do:
    a=23
    CCFunbind(a)
    and it will work in either mode - it will unbind a top level variable.
    The CCR number for my request for such a function in SKILL is 1320516.
  • tweeks
    This is cool.  :)  Thanks Andrew!
    I learned another trick from you: temporarily rebinding woport for situations where getWarn isn't enough.
    Also, using (if (theEnvironment) ...) to check for SKILL++ mode.
