  3. nil IS a list...
  • Replies 8
  • Views 21132
nil IS a list...
tweeks
tweeks over 12 years ago
ddGetObjChildren(
b_objId
=> l_children | nil
When you say l_children, isn't it already implied that the list could be empty?  After all, if the object has no children, then you get nil, which is just a zero-length list of children.  So shouldn't the return type be simply l_children, like this:
ddGetObjChildren(
b_objId
=> l_children
Just sayin'....
  • skillUser
    skillUser over 12 years ago
    Well, yes, but it is clear enough to say that the return value is nil otherwise some folks might expect (nil) to indicate no children, so it doesn't hurt to be redundant in this case I think...
    Just my $0.02 worth.
    Lawrence, I agree. The redundancy doesn't do any harm. My £0.02 ;-)
  • tweeks
    That's a good point.
    Curiously, I haven't encountered many SKILL functions that return a (nil) so as to distinguish the result from nil.  In fact, the only one that comes to mind is errset, so that you can distinguish a function that returns nil successfully from one that throws an error.
    It just so happens that today I thought about writing a macro exists1 that is just like exists except it takes the car of whatever exists returns, since I'm usually searching for the first thing matching the predicate, not the rest of the list starting with the first thing matching the predicate....  However, if I were searching for nil, I wouldn't know whether (exists1 x myList (p x)) => nil means nil is present in myList, or nil is not present!  (This is one disadvantage to not having a separate boolean type like Scheme.  Of course, even then I'd have the same issue if I were searching for a Scheme boolean false #f object... which is one disadvantage to not having a Maybe type like Haskell....)
    I could have exists1 return a wrapped result, so that I'd get (nil) if nil was in there, and nil if it wasn't, but that's what exists does... :)
    For me, it seems more convenient to live with the ambiguity and just return nil in either case, since I never search for nil using exists anyway -- I would use something like (apply (and ...)) or andmap for that.
  • tweeks
    Andrew Beckett said:
    My £0.02 ;-)
    That's "two pence", or "toppence", right?  (Sorry: ignorant American!)
    WOAH I just realized that "pence" sounds just like the French pense ("think"), hence "pence for your pense" is a little pun that fails to make sense when you s/penny/pence/ ...
    If looking for any nils present in the list, I would use:
    (forall elem lst elem)
    as that's probably more expressive than (apply or ...).
    In general I always advise against overuse of macros. Peter Norvig makes a good point in Paradigms of Artificial Intelligence Programming about this. "The first step in writing a macro is to recognize that every time you write one, you are defining a new language that is just like Lisp except for your new macro. The programmer who thinks that way will rightfully be extremely frugal in defining macros. Introducing a macro puts much more memory strain on the reader of your program than does introducing a function, variable or data type, so it should not be taken lightly. Introduce macros only when there is a clear need, and when the macro fits in well with your existing system."
    And yes, that is two pence or "tuppence" (with a u rather than an o)!
  • tweeks
    Oh yeah.... and forall would handle longer lists too, due to the arglist length limitations of apply.
    Ha I just got that book!  Judging from my preliminary skimming, it looks truly hardcore.  I like that Norvig explains the true origins of lambda on p.20, going all the way back to Russel & Whitehead's caret notation in Principia Mathematica.
    Reminds me of the "feed the birds" song from Mary Poppins, which is one of my primary sources for information on life in the UK, along with Top Gear and Doctor Who.
    Is your hometown pronounced like "berk-shy-er" or "berk-sure"?
    Berkshire (full name "The Royal County of Berkshire")is a county (not a town), and it's pronounced bark-sheer (sort of).
  • tweeks
    Thanks for the link!
    Such a beautiful place, with such a long and fascinating history....  I absolutely must visit before I die.
