  3. ReportField columns to be made stretchable
  • Views 14800
GaneshShamnur
GaneshShamnur over 12 years ago
Can the report-field column widths be made to stretch/shrink according to the Form's width-size ?
I was able to control the sizing of a complete ReportField but not its columns.
When a form with report-field was stretched, its columns wouldn't accordingly resize resulting in an extra blank column as the last column when stretched !
When form was shrinked, the columns don't resize but truncate the view of few right-most columns. However scroll bars appear using which, the column contents can be viewed.
Ganesh
    Ganesh,
    The columns are stretchable - they just don't auto-resize as the parent form is resized (assuming you've used attachments to allow fields to stretch with the form).
    You should contact customer support to request this as an enhancement. It might be possible with some of the changes in UI capabilities that we are implementing in IC617 (not certain though).
