  3. executing a procedure from command line
  • Views 15517
harishgurram
harishgurram over 12 years ago
hi,
I have written a skill procedure in a file, and loading the file with the dbAccess -load <skillfie>
Is it possible to execute the procedure i written into the file at the command line using dbAccess
how to do this?
  • skillUser
    skillUser over 12 years ago
    Hi Harish,
    unless I've misunderstood, your file only contains the procedure definition and does not then invoke or call the function, is that right?  What you want is something like a -replay command line argument, but I don't think it exists for dbAccess, so your choices are:
    1. Create another file that loads the code and then executes it, invoke with dbAccess -load <filename>
    2. Use virtuoso -replay <filename> on the file from item 1) above
    There might be other possibilities, but if I understood your question then I think these are your options.
    Lawrence.
