  3. How to put data into memory for paste using SKILL
  • Subscribers 150
  • Views 15384
XinjiePI
XinjiePI over 12 years ago
Hi All,
 I have a procedure() that can get a variable. Is there any methods can add to this block to put this variable into memory? which I could use mouse middle button to paste this data after I finish running the procedure()?
Any comments are highly appreciate!
Xine
    Xine,
    Your question was not very clear, but I think you're asking for a way to populate the "clipboard"  from SKILL. There's hiGetClipboard() to retrieve it, but no public function to set the clipboard contents.
    You should contact customer support to request this.
  • XinjiePI
     Thanks for your reply. Yes I need one function to populate data to clipboard. I would contact them to see what happened.
    Thank you.
    Xine
  • uschi
    uschi over 12 years ago
    Maybe this works for you, it puts the string into the mouse-buffer:  p, li { white-space: pre-wrap;
    MyString="ps -aux"  p, li { white-space: pre-wrap; }
    sprintf( cmnd "echo '%s' | xclip -i" MyString) p, li { white-space: pre-wrap; }
    system( cmnd )
    regards,
    Uli
