  3. Skill Pcells for switching layers on and off for a artw...
  • Subscribers 150
  • Views 15128
Skill Pcells for switching layers on and off for a artwork
skillforpcells
skillforpcells over 11 years ago
I am new to skill, can you please list the ways to write the skill file for switching the layers off and on for a given figure. Also to iterate the figure in a array pattern.
Apart from writing the skill file, I also want to know about the procedure for reading the skill file to create a Pcell. Is there a way we can create a Menu and later define the callbacks.
  • theopaone
    theopaone over 11 years ago
    A pcell is a cellView master that has a set of parameters assigned to it. The contents of a pcell are defined by the values of the parameters on the instance of the pcell.  You would have to have a parameter on your pcell to control what shapes are drawn. A figure, actually a shape, has a single layer. You would have to create a new shape on a different layer if that layer is turned on, either by copying the original shape or calculating a new one.
    Some requirements:
    How many parameters should I use, one or one for each optional layer? What would be the allowed values of the parameter? What should be the default value and action in the pcell?
    ;; This code is guaranteed not to work
    pcDefinePCell( list( ddGetObj(libName) cellName viewName viewType )
       ( (optionalLayers 'list () ) ; parameter to control optional layers - list of layer names
          ( rows 'int 1 ) ; Number of rows
          ( columns 'int 1 ) ; number of columns
          ( xPitch 'float .1 ) ; Pitch between columns
          ( yPitch 'float .2 ) ; Pitch between rows
       figList = foreach( mapcar layer optionalLayers
                              dbCreatePolygon( pcCellView layer shapePoints ) )
     ;; To copy to an array pattern, the first set is already created so start from 2
      xStep = yStep = 0.0
       for( x 2 columns
         xStep = xStep + xPitch
         yStep = 0.0
         for( y 2 rows
              yStep = yStep + yPitch
              foreach( fig figList dbCopyFig( fig pcCellView list( xStep:yStep "R0") ) )
         )  ; fory
       ) ; for x
    That is an example of how it can be done.
    I don't understand your second request. If you create the pcell definition and load it into the CIW, you will have a pcell. You can create a CDF to go along with the pcell which would give you the option of having choices and callbacks.
    Ted
