  3. Create condition based parameter check options in pcell
  • Subscribers 150
  • Views 17294
skillforpcells
skillforpcells over 11 years ago
I am working on creation of Pcell which has around 15 parameters in form of check box(value type = boolean) and each check box enables a object in the Pcell. I want to create condition based checkbox where 8 checkbox are primary and independent and rest 7 are dependent on previous 8 and enables or disables depending on the 8 primary one.
For example in the code below(with only 4 parameters(checkbox)) which is generated by graphical pcell option (as I am beginner in Pcell skill and want to start with a working code), If m1 is selected then contLD checkbox is disabled and if m1LD is selected by user then cont is disabled. How can this be done.
Also is there a possibility I can make one checkbox behave differently based on primary checkboxes( for example m1 and m1LD are primary and instead of having two parameters cont and contLD I can have just cont which behaves as cont or contLD depending on whether m1 or m1LD are selected respectively )
pcDefinePCell(list(ddGetObj("Pcells") "MESH_SKILL" "layout")
    ((cont boolean "TRUE")
    (contLD boolean "TRUE")
    (m1 boolean "TRUE")
    (m1LD boolean "TRUE")
    let((m1 cont contLD m1LD pcMember
        pcStretchGroup stretchOffsetX stretchOffsetY pcLib pcMaster
        pcInst pcTerm pcPin pcPinName pcNet
        pcTermNet pcNetName pcTermNetName pcMosaicInst pcParameters
        pcParamProp pcStep pcStepX pcStepY pcRepeat
        pcRepeatX pcRepeatY pcIndexX pcIndexY pcLayer
        pcPurpose pcLabelText pcLabelHeight pcPropText pcParamText
        pcCoords pcPathWidth pcPolygonMargin
    (pcLib = (pcCellView~>lib))
    (pcParameters = ((pcCellView~>parameters)~>value))
    (pcParamProp = car(exists(prop pcParameters
            ((prop~>name) == "m1")
    (m1 = (pcParamProp~>value))
    if(((pcParamProp~>valueType) == "boolean")
        (m1 = (m1 == "TRUE"))
            ((prop~>name) == "cont")
    (cont = (pcParamProp~>value))
        (cont = (cont == "TRUE"))
            ((prop~>name) == "contLD")
    (contLD = (pcParamProp~>value))
        (contLD = (contLD == "TRUE"))
            ((prop~>name) == "m1LD")
    (m1LD = (pcParamProp~>value))
        (m1LD = (m1LD == "TRUE"))
    dbReplaceProp(pcCellView "viewSubType" "string" "maskLayoutParamCell")
    dbReplaceProp(pcCellView "_pcCompiledCounter" "int" 1081)
    if(m1LD then
        (pcLayer = 8)
        (pcPurpose = "drawing")
        (pcInst = dbCreatePolygon(pcCellView
            list(pcLayer pcPurpose)
            list((-2.5:2.5)
            (2.5:2.5)
            (2.5:-2.5)
            (-2.5:-2.5)
            (-2.5:-1.5)
            (1.5:-1.5)
            (1.5:1.5)
            (-1.5:1.5)
            (-1.5:-1.5)
            (-2.5:-1.5)
    if(m1 then
        (pcLayer = 8)
            list((2.5:2.5)
            (1.0:2.5)
            (1.0:-1.0)
            (-1.0:-1.0)
            (-1.0:1.0)
            (1.0:1.0)
            (1.0:2.5)
            (-2.5:2.5)
            (-2.5:-2.5)
            (2.5:-2.5)
    (pcLayer = 2)
    (pcInst = dbCreateRect(pcCellView
        list((-2.5:-2.5)
            (2.5:2.5)
    if(cont then
        (pcLayer = 7)
            list((1.0:1.5)
            (1.5:2.0)
    if(contLD then
        (pcLayer = 7)
            list((1.0:-2.0)
            (1.5:-1.5)
    ) t
  • theopaone
    theopaone over 11 years ago
    The interrelationship of parameters is handled by the CDF on the master. The CDF determines how the parameters are displayed and what happens after they changed. In your case, the CDF has 4 Boolean parameters, cont, contLD, M1, M1LD.  The callback for the parameters should check the values and modify the 'editable or 'display attributes on the related parameters:
    This code has not been tested, you mileage may vary.
    cdfCreateParam( cdfId ?name "M1" ?type "boolean" ... ?callback "myDeviceCallback( cdfgData 'M1 )" ... )
    procedure( MESH_SKILL_Callback( cdfId param )
    case( param
      ( 'M1
          if( cdfId->M1->value == "TRUE" then
             cdfId->cont->editable = t
    ;; Set contLD to be not editable and FALSE
             cdfId->contLD->editable = nil
             cdfId~>contLd~>value = "FALSE"
        else
    ;; Set cont to be not editable and FALSE
             cdfId~>cont~>editable = nil
             cdfId~>cont~>value = "FALSE"
        ) ; if
      ) ; M1
     ) ;case
    ) ; procedure
    The callback can manage the relationships between the parameters. The pcell parameters do not have that relationship.
     Ted
  • skillforpcells
    Thanks theopaone for your reply.
