  3. To insert custom banners on the design view
  • Subscribers 150
  • Views 15275
Leesh
Leesh over 11 years ago
Hi. I want to ask how to fix my code to add custom banners
Code is following
procedure(verifyMenu(args)
let((winId new_verify new_verifyMenuList)
winId = args~>windows
new_verify = hiCreateMenuItem(
 ?name       'new_verify
 ?itemText  "New_Verify"
 ?callback  "uinewverify()"
new_verifyMenuList = list(new_verify)
new_verifyMenu = hiCreatePulldownMenu('new_verifyMenu "New_Verify" new_verifyMenuList)
));let
deRegUserTriggers("maskLayout" nil nil 'new_verifyMenu)
When I load this function, and open maskLayout view, following error occured
*Error* get/getq: first arg must be either symbol, list, defstruct or user type - "LibraryName"
How should I fix my code?
    A few problems:
    1. The function name you've called in the deRegUserTriggers is new_verifyMenu, but the function is called verifyMenu
    2. You've called it as a post-install trigger, whereas it should be a menu trigger (i.e. the third argument)
    3. The args parameter is a disembodied property list, and so you must use -> rather than ~> (that's what is causing the primary error message)
    4. A user menu trigger should return a list of pulldown menus
    So these corrections to your code will do the job:
    procedure(MyVerifyMenu(args)
        winId = args->windows
         ?name       'new_verify
        list(new_verifyMenu)
    );let
    deRegUserTriggers("maskLayout" nil 'MyVerifyMenu)
  • theopaone
    theopaone over 11 years ago
    I can't be sure why you are getting that particular error message but you are using the triggers incorrectly.
      1                  2   3      4
    Quote: deRegUserTriggers("maskLayout" nil nil 'new_verifyMenu)
    The menu trigger is the third argument and is the name of the function which returns a list of the menus to be added to the banner menu. The 4th argument is the name of the post install function and should not be used to install a menu.
     Your function should return a list of the menu you want to add:
    Return Value => list(new_verifyMenu) and you should register the function symbol for the third argument.
    deRegUserTriggers("maskLayout" nil 'verifyMenu nil )
    I'm not at a Virtuoso terminal so I could not test the code. I've tagged another relevant post with menuTriggers.
    Ted
