  3. Apply netset properties to all instances within a schem...
  • Subscribers 150
  • Views 17887
Apply netset properties to all instances within a schematic
jsaenznoval
jsaenznoval over 11 years ago
Hi everyone!
I have imported a verilog schematic in virtuoso and I want to check successfully LVS and create a analog_extracted view but I have some problems trying to pass LVS. My digcells use netset properties with net expressions to define vdd and gnd pins with default values set to gnd! and vdd!.  However, my power supply and ground supply pins are tied to dvdd and dgnd netnames, thus I need to change all netset properties in all digital cell views of my schematic. I have created a schematic and place there a symbol of my schematic with netset properties adequately set and it has successfully matched with my layout. However, when I extracted  my lvs_extracted view I get the following subckt:
subckt rh_drv_pulse_controller clk rst_n cmd_disable_n_i addr_i\<1\> \
        addr_i\<0\> cmd_enable_n_i sp_n_i ocp_i uvp_i otp_i ohd_i\<3\> \
        ohd_i\<2\> ohd_i\<1\> ohd_i\<0\> cmd_o\<3\> cmd_o\<2\> cmd_o\<1\> \
        cmd_o\<0\> pulse_o double_o false_o fault_o cmd_disable_o dgnd \
        dvdd inh_ground_gnd inh_power_vdd
    drc4851 (n_218 pulse_o inh_ground_gnd inh_power_vdd) BURHX2
drc4844 (n_286 double_o inh_ground_gnd inh_power_vdd) BURHX2
The digcells has inherent power and ground pins, which are not tied to dgnd and dvdd.
I could change the netset properties by hand for all cells, but it takes a long time. How I can automatically set  inherent nets to dgnd or dvdd pins? Is there anybody  with the SKILL code for it?
Thanks!
  • jsaenznoval
    It was quite easy applying the code of Solution ID 1843120. Due it is a task that I have frequently done, I would like to add this code to my Schematic-{L,XL} menu. How can I do it?
  • theopaone
    theopaone over 11 years ago
    ;Create a function to create the menu, it returns the menuID:
    procedure( CreateMyMenu(@optional _ignore )
    ;Create a menu item that exercises the callback:
    myItem = hiCreateMenuItem( ?name 'myMenuItem ?itemText "Press Me" ?callback "doSomething()" )
    ;Create a menu to be inserted into the field:
    menu = hiCreateMenu( 'myBannerMenu "MyTitle" list(myItem) )
    ;; This procedure can be used manually by installing the menu:
    hiInsertBannerMenu(hiGetCurrentWindow() CreateMyMenu() hiGetNumMenus(hiGetCurrentWindow()) + 1 )
    To automatically insert the menu, set a trigger based on the view type:
    deRegUerTrigger( "schematic" nil 'CreateMyMenu nil )
    There is some error checking that must be in place, you only want to insert the menu once in a window and you want to make sure the user trigger is not already set.
    Ted
