  3. Is there a function from calculator or ocean script that...
  • Views 15467
Is there a function from calculator or ocean script that can read a value from x-axis given the condition of y-axis?
Alex Liao
Alex Liao over 11 years ago
I have a comparator circuit. I have print out an waveform of the Vout+. The x-axis is the time and the y-axis is the voltage. For example the voltage supply is 1V. I can see when the voltage raises from 0V to 90% of 1V, which is 900mV, how much time is needed or what is the current time in ns when it reaches 900mV.
I am wondering if there is a function that can return you one specific point (in ns) on the X-axis when Y reaches 900mV. Thus I do not need to manually measure/observe it. Maybe I need specify any time range such that it can only return me one value because the output wave maybe periodical and thus there are lots of point satisfying this requirement of 900mV on y-axis.
I am using Cadence ADE to run simulation and hope there is a function in the calculator or any ocean script that can do this.
Alex
    cross() is what you want. You could use clip if needed to constrain the x-range but you can tell it which crossing you want. Regards, Andrew
