  3. strange problem with ocean processing
  • Views 14696
NcfC
NcfC over 11 years ago
I'm running ocean, from IC version 5.1.41, on a openSuse 13.1, and I got a strange problem when using "if" loop.
If I place 3 statements inside the loop, as shown below, I don't have any problems
n = 0
if( ( n == "1" )
then
w1 = 1.0
w2 = 1.0
w3 = 1.0
else
w1 = 1.0
w2 = 2.0
w3 = 2.5
but, if I place 4 or more statements, I get into errors:
n = 0
if( ( n == "1" )
then
w1 = 1.0
w2 = 1.0
w3 = 1.0
w4 = 1.0
else
w1 = 1.0
w2 = 2.0
w3 = 2.5
w4 = 1.5
SYNTAX ERROR found at line 2 column 1 of file *string*
*Error* lineread/read: syntax error encountered in input
*WARNING* (reader): too few right parentheses, ')' added at EOF
ocean>
After the "ocean>" prompt, the terminal is irresponsive and the only way out is to kill the terminal. Does someone have any ideas on why this happens and/or how to solve it?
Thanks very much in advance.
    Sorry for the delay - this post was stuck in moderation (and I'd not had any moderation notifications until yesterday). I just tried this and it works for me. Are you sure you didn't have some strange characters in there somewhere?
    Kind Regards,
  • NcfC
    Hi, Andrew.
    thanks for the reply.
    Yes, I'm sure there's no strage characters. It bothers me because the same code works on another of our machines. The only difference between the 2 machines is that the other one has an older OS (opensuse 11.4) while this one has a newer version (opensuse 13.1). I first though it could be same OS update that could be the cause but I couldn't figure it out. But since opensuse is not one of the supported platforms, I didn't find any docs that could help me.
    thanks again for the reply.
    best regards,
