  3. ddIsPathManaged and ddIspathManageable
  • Views 14651
Saikrishna14
Saikrishna14 over 11 years ago
As given in the description ddIspathManageable returns t  if the  specified path is supported by a design management system.
The function ddIspathManaged returns t if the specified path is currently managed by a design management system.Its given in the description that the path is managed if the file associated with the path is checked in.I have used the function ddIsPathManaged to check if the given path is checked in or not,Ideally it should return nil value if the path is never checked in but it is returning t .Is there a way to check if the given path is checked in or not?
  • skillUser
    skillUser over 11 years ago
    Hi Saikrishna,
    I think that you may want to look at the ddGetObjDMSys() function, you pass it the database (dd) object ID and it returns the name of the DM system or maybe ddPathGetDMSys() - pass the path to the object.  I have not tried either of these, so they may not give the answer you are looking for.  If these are not what you want, then maybe gdmstatus() is the function you need - you will probably need to parse the result back yourself.
    regards,
    Lawrence.
  • Saikrishna14
    Thanks Lawrence! I have tried ddPathGetDMsys() but i didn't find it.I have found a work around.Thanks for the reply.
