  3. need help with three skill commands...please!
  • Replies 10
  • Subscribers 150
  • Views 19245
boomme
boomme over 11 years ago
I have what I  3   questions.
question 1...
for the skill command...    dbSetShapeColorLocked(d_shapeID    g_setLocked)
what are the values for the variable g_SetLocked ?
(I am trying to unlock the shape's colors so I can make a hotkey toggle to switch colors.)
question 2...
what is the skill command to highlight a single shape?
question 3...
I am trying to use the following common: dbIsShapeColorLocked(obj)
where obj is a shape ID... as in:
sel = geGetSelSet()
foreach(obj sel
if(dbIsShapeColorLocked(obj) == "t"
the dbIsShapeColorLocked command does not seem to be returning "t" or "nil" but rather a database ID like:
db:0x7838b470
any idea why?
Thanks for any and all help!
-T
  • boomme
    so... I've figured out the answer to question #3.... no quotes around the t or nil. I'm still needing some help with questions 1 & 2. Sure hope someone comes to my rescue.
  • boomme
    well... no I figured out question #1 on my own...same answer... get rid of the quotes. Still looking for the answer to #2 .... how can I highlight single shape (not a net)?
  • theopaone
    theopaone over 11 years ago
    Questions 1 and 3 are related to double patterning while #2 uses a different group of functions, the hilight set. You first have to create the hilight set with geCreateHilightSet. Then you enable it, and push it to the stack: gePushHilightStack. Finally you add objects to the set geAdHilightFig and they are highlighted. The documentation is in the SKILL Design Environment document.
  • boomme
    Thank you for answering Theo...
    So... FYI- I have trouble with the skill finder - it lists generic variables such as:
    geCreateHilightSet(
    d_cellview
    l_layerPurposePair
    [ g_notGlobal ]
    geAddHilightFig(
    g_hlSetId
    d_figId
    [ g_drawAll ]
    but doesn't list what are valid entries for [ g_notGlobal ] or [ g_drawAll ] - I'm guessing these are T or NIL values?
    trying to use your psuedo code instructions above, I have written the following code... it does not work....
    cv = geGetEditRep()
    geSelectAllFig(cv)
    sel = geGetSelSet()
    pp = list("hilite" "drawing")
    HilightID = geCreateHilightSet(cv pp t)
    gePushHilightStack(HilightID)
    foreach(obj sel
    geAddHilightFig(HilightID obj)
    ....so, what am I not doing right?
    Thanks again for your help.
    -Terry
    Hi Terry,
    First of all, the finder is just a very brief reminder of the arguments and basic outline of the function. More detail is found in the full documentation which expands (usually) on each argument and hopefully gives examples. So please look in cdnshelp for more detail.
    I suspect the main issue you have is that you have not enabled the hilight set. I don't have the documentation to hand, but it is something like:
    HilightID~>enabled=t
    (I can't remember whether it is enabled or enable). Without this, you won't see the set.
  • theopaone
    Thanks Andrew.
    I don't use finder very much because of the limited amount of help available, I may use it to get a listing of potential commands -> geHi* and then look in cdnshelp for more detail.
    I forgot about enabling the hilight set, I have encapsulated the hilight commands so I can highlight an object and it will create the hilight set without an explicit call.
    The enable action is hilightId->enable = t
    If you create a non global set you have to push the hilight set with gePushHilightStack(hilightId)
    Ted
  • boomme
    HAAAA!  that worked guys.... I say thank ya very much.
    so...
    last questions.  what's the command to unhighlight these guys now?
    and... where do I find this cdnshelp thingy???... Is it under the main Cadence help pulldown? if so, what title topic?
    I'm a contractor, so i might have limited access.
    -terry
  • boomme
    figured out the unhighlite... but still would like to know where to find the cdnshelp thing - thanks again so much.
    You could either do `cds_root virtuoso`/tools/bin/cdnshelp from UNIX (this may be in your search path anyway, so just typing "cdnshelp" may work - otherwise it's probably a function of how it has been set up at the site you're working at, so you might need to ask one of the local CAD people?) or just use Help->Virtuoso Documentation from the CIW. You might need to do View->Show Navigation once it has started.
    Then you can search for the function you want.
  • boomme
    Thanks Andrew, wish I had known about how to get to this resource 15 years ago... probably would have saved a a couple of years worth of hacking. :)
