  3. Determine SPICE file set as instance cell view in hierarchy...
  • Views 15656
Determine SPICE file set as instance cell view in hierarchy editor
JeffDyck
JeffDyck over 11 years ago
In the Virtuoso Hierarchy Editor, a user can right-click and select "Set Cell View->Specify SPICE Source file".  I have two questions related to this interface.
1. While traversing the hierarchy through SKILL calls, how can I detect that an instance has been set to use a SPICE file (note hdbIsAtStopPoint seems to return nil)?
2. Can I use SKILL to determine the name of the file?
Thank you.
    Not currently. There's an enhancement CCR number 1296907 asking for this. I suggest you contact customer support and ask for a duplicate to be filed on your behalf to increase the likelihood of this being implemented.
    Kind Regards,
  • JeffDyck
    Thank you very much for the reply, Andrew.
