  3. Use terminal net name as value for an instance's CDF pa...
  • Views 3982
Use terminal net name as value for an instance's CDF parameter
dontpanic
dontpanic over 11 years ago
Hi all! I am trying to find a way to use the name of the net that is connected to an instance's terminal, as a string value for one of the instance's CDF parameters.
In particular, I have a verilog-A component "sample2disk(vIN)" which when instantiated in an schematic samples and dumps to a text file the voltage "vIN" at its input port. This cell has a string parameter "signal_name" which I use to generate the output file name. The component works fine, but currently I need to hard-code the "signal_name" parameter for every instance of this component that I use in an schematic. For example, if I have 2 instances of this component connected to the signals "stage1_vout" and "stage2_vout" in my schematic, then I would need to hard-code these names as values for the corresponding "signal_name" parameters. Instead, I would like to use a skill function that returns automatically these signal names so that they don't not remain hardcoded, allowing for a correct operation when reusing this cell multiple times in an schematic or when copying and pasting across schematics.
I would be really grateful if someone could please help me to figure out how to achieve this behavior (if possible at all).
Thanks in advance for any help!
Cheers,
Jorge.
    Hi Jorge,
    This can be done with a custom netlisting procedure. For example, if you have the following VerilogA code:
    // VerilogA for mylib, sample2disk, veriloga
    `include "constants.vams"
    `include "disciplines.vams"
    module sample2disk(vin);
    input vin;
    electrical vin;
    parameter string netname="dummy";
    integer handle;
    analog begin
        @(initial_step) handle=$fopen(netname,"w");
        $fdisplay(handle,$abstime,V(vin));
        @(final_step) $fclose(handle);
    end
    endmodule
    Then you can use this netlist procedure (instructions in the comments as to how to set up the CDF to reference it; because VerilogA normally uses view-specific CDF, you have to use SKILL to change it as there's no UI for it on the Edit CDF form). Then make sure the code is loaded (e.g. from your .cdsinit).
    /* abNetlistSampleToDisk.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Nov 10, 2014
    Modified
    By
    Assuming that the veriloga model has a parameter called netname, and a single pin
    Do this to set up the view-specific CDF
    lib="mylib"
    cell="sample2disk"
    view="veriloga"
    paramName='netname
    almSetParameterList(lib cell remove(paramName almGetParameterList(lib cell ?view view)) ?view view)
    almSetNetlistProcedure(lib cell 'abNetlistSampleToDisk ?view view)
    SCCS Info: @(#) abNetlistSampleToDisk.il 11/10/14.17:16:24 1.1
    procedure(abNetlistSampleToDisk(inst)
        let((signals )
            nlPrintInst(formatter inst)
            signals=nlGetSignalList(inst)
            nlPrintString(nlGetNetlister(inst) " netname=\"" car(signals) "\"")
    This will netlist ensure that you end up with a lines in the netlist such as:
    I15 (net9) sample2disk netname="net9"
    I14 (out) sample2disk netname="out"
    Hope that helps!
    Kind Regards,
  • dontpanic
    Dear Andrew,
    thank you so much for your reply and the sample code; it achieves exactly what I meant. Even though I admit it's still a little cryptic for me (never saw before any netlisting functions!), I was able to modify it for the case of a multi-port component, and also to automatically determine the parent cellview name and library path at netlist time, for which I used the functions "nlGetTopCellName(nlGetDesign(nlGetNetlister(inst)))" and "dbFullLibPath(nlGetLibName(inst))". Before I tried to enter these functions as values in the respective component's CDF, but without any success (even after checking the "parse as CEL" option in the associated CDF properties). I guess this means it's not possible to use skill functions as values in an instance's CDF fields, right?
    Thanks again for your help; it's really appreciated.
    Cheers,
    Jorge.
    Hi Jorge,
    CEL is not SKILL. It's something called "AEL" (there's a bit of a historical inconsistency - some places it is called CEL, but most places it is called AEL). This is the "Analog Expression Language". Essentially it's a set of functions and expression syntax that is understood by CDF, and generally translates into equivalent functions that can be evaluated natively in the simulators.
    So you can use SKILL functions in the callback fields in the CDF (these are supposed to SKILL), but not in any value fields.
    Cheers,
  • dontpanic
    Thanks for the further clarification Andrew; finally I can make my peace of mind w.r.t to that idea.
    Cheers,
    Jorge.
