  3. Triggers for physConfig view
  • Subscribers 148
  • Views 14992
dmay
dmay over 11 years ago
Is there a way to setup a save trigger for physConfig views? For regular cellviews you can use dbRegPostSaveTrigger to run code after the save. I'd like to be able to trigger some code to run after a physConfig view is saved. I could probably get something working if I could trigger from the close of the window or the changing of the mode ("a" to "r" or "r" to "a"). Anyone have any suggestions?
Derek
    Derek,
    I don't believe there are any "cph" APIs to register save triggers (which is what would be needed). You can't register "de" triggers on the CPH window either (as far as I know) because it's not a Design Editor window.
    Please contact customer support. This will almost certainly need an enhancement request (unless I'm mistaken, which is of course possible).
