  3. Keyboard entry in a layout window
  • Views 15508
Arun14787
Arun14787 over 11 years ago
I have a requirement in which a SKILL code should be able to read the keyboard entries done in a layout window. For ex. if i press a bindkey "1" in a layout window, then a SKILL code should read whatever floating number i enter in the same window. Once i hit enter, then the entered floating number should be stored in a variable. How this can be done in SKILL?
Thanks in advance,
Arun
    Whilst this could conceivably be done by defining bindkeys for all the numbers and "." and then collecting a sequence, it's a bit messy (and a rather odd use model).
    Wouldn't it be better to add a toolbar with a type-in field.
    A couple of relevant posts if you want to pursue the idea of a multi-key bindkey (this isn't exactly what you want, but may give the idea):
  • dmay
    dmay over 11 years ago
    This should do the trick:
    hiSetBindKey("Layout" "<Key>1" "_USERNUM = enterNumber(?prompts list(\"Enter new _USERNUM in CIW\"))")
    Derek
