  3. How Can Utilize a dwindow in the same fashion as an Assistant...
  • Views 16617
How Can Utilize a dwindow in the same fashion as an Assistant in virtuoso so that it is available on All design windows .
Kevin Guay
Kevin Guay over 11 years ago
I have created a dwindow with a form in side of it that works fine on a window to window basis but I wish it to act like the pallet window whereas it is available in all windows
As well I want it added as a action menu item in the assistant menu items like Annotation Browser
I have been able to add it to the window menu in IC6.1.5 but in IC6.1.6 it does not add  As well it does not add to the right click Assistants Menu in either version
Any Ideas are appreciated
Kev
  • theopaone
    theopaone over 11 years ago
    Hi Kevin
    From what I can see, a dockable window (dwindow) can only be associated with one session window. I think you have to make an assistant to make it available to all windows.
    You may want to include some of your code so we can get a better idea of what you want to do and what is failing.
    Ted
  • Kevin Guay
    Ted
        Hey how are you doing.. Thanks for the reply  My code is nothing special just using hiCreateDockWindow and hiDockWindow   I think you are correct I would prefer making it an assistant but I could not find the applicable documentation on making assistants  can you please point me in that direction..   Thank you very much for your help
    Kev
  • drdanmc
    drdanmc over 9 years ago
    I have the same questions as Kevin. Any pointers towards documentation or examples on making an assistant?
    -Dan
    Does this article help?
  • drdanmc
    Sort of. It has a nice example of changing out the contents of a form in a dockable window. That's pretty useful. I still can't seem to get this new dock window to show up in the window->assistants menu (without jumping through all sorts of hoops) or the banner popup at all (can't seem to figure out how to access the banner popup). What is interesting is that if I run the example in that article with no modifications, it creates a new session, a new window, adds the dockable window, and the dockable window *does* show up in the banner popup and I fail to see which part of the code causes that addition to the popup. So this is mystery #1 (getting the dockable added to the assistants menus in the two spots).
    In Ted's first reply he implies that an assistant is somehow different than a dockable window and that an assistant can be added to more than one window (a dockable window can only be added to a single window at a time). If this is indeed true, it would be helpful for me to figure out how to do that (create an actual assistant instead of multiple dockable windows, each with their own form as forms can't be instantiated in more than one window at a time and dockable windows are tied to a single session+window). My other option is I can keep track of all of my dockable windows and put in place some code that keeps groups of them synchronized (sort of like the palette is synchronized across layout windows) but that sounds like it may start to be a bit of a book keeping headache.
    -Dan
    p.s. here is the (very ugly with no error checking) code I hacked together to insert something into the Window->Assistants schematic menu:
    <pre>
    win = getCurrentWindow()
    menus = hiGetBannerMenus(win)
    window_menu = nil
    foreach( m menus
    m2 = eval(m)
    ;;printf("m2~>?? = %L\n", m2->_menuTitle)
    when( m2->_menuTitle == "&Window"
    window_menu = m2
    foreach( m hiGetMenuItems(window_menu)
    when(boundp(m)
    m2 = eval(m)
    when(m2->_menuTitle == "&Assistants"
    a_menu = m2
    my_act = hiCreateAction(
    ?name 'my_dock_act
    ?iconText "Example Dock"
    ?toolTip "my example dock tooltip"
    ?enabled t ?checkable t ?checked t
    ?callback "my_callback()"
    hiInsertMenuItem(a_menu, my_act, 100)
    </pre>
