  3. path, can automatically catch contact or via center ?
  • Subscribers 150
  • Views 15188
James Hsu
James Hsu over 11 years ago
Kindlypeople help:
how to drawing the path,
thank you.
  • theopaone
    theopaone over 11 years ago
    Can you give us more information? What tool are you using (interactive router? batch router?) What release?
  • James Hsu
    We are using IC 5.1.41.
    I want to do the metal  drawing.
    When I am drawing :  use Path Bindkey. the first point is via  centre .
    I want to know,what kind of the skill function can auto  catch thw via centre .
    thank you .
  • theopaone
    I don't know if this is applicable to 5141 as it is such an old release. I don't have access to it.
    In IC61, you can turn on gravity and setting the gravityType to nexus or pin. This is documented in the VLE Help manual. Check the corresponding manual in your release for gravity, it is long existing functionality.
    Ted
