  3. How To Move of Objects And Polygon Edges
  • Subscribers 150
  • Views 15945
harishgurram
harishgurram over 11 years ago
     Is there any skill commands to directly move edges of polygon from one location to other, with reference to some layer.
or moving object with reference to some layer(say prBoundary).
Ex: I have a via layer in my layout at 0.05 distance from prBoudary, i want to move this to some where else.
how to do this. is there any procedure availbale, or direct skill command is there?
Harish
    You could use leStretchFig()
  • theopaone
    theopaone over 11 years ago
    To do it programmatically, you have to calculate the edge and replace the points on the polygon object or the bounding box on the rectangle object.
