  3. How to replace a string in a file?
  • Subscribers 150
  • Views 17701
apskohli
apskohli over 11 years ago
I need to search and replace a string in a file using SKILL.
I want to do this without creating any temp files i.e. open
file in I/O mode and make edits. I was able to this using
two files using something like the code below. Can somebody
suggest a more efficient way?
Aman
infile(xx);
outfile(yy);
when( inPort
    while( gets( nextline inPort)
rexcompile();
rexReplace();
fprintf(yy);
close(yy);
    You can't open the file and modify it in place. You could of course read the entire contents into memory, do the substitution there, and then write out to the same file name. Whether that is efficient depends on the size of the file...
  • apskohli
    Can you please elaborate the data structure I can use to store the entire file and then read back line-by-line to replace text?
    Aman
  • apskohli
    Hello Andrew,
    I would really appreciate your inputs on this?
    Aman
  • theopaone
    theopaone over 11 years ago
    The simplest data format to use is a list, in your read loop add the current line to the beginning of the list using cons after changing the text in that string.
    Re-open the file for write then loop through the reverse of the list to print out the data.
    Then close your file.
    Ted
    Thanks Ted - meant to reply but the last few weeks have been rather busy and travel-heavy, so I'm rather behind with Forum responses.  Andrew
