  3. ipcskillprocess control
  • Views 19002
skillseeker
skillseeker over 11 years ago
I am using ipcSkillProcess to extract Cadence schematic information. I am sending a command to a skill procedure from perl and seems to be working fine.
lcid = ipcSkillProcess("DisplaySchematicTree")
while(ipcIsActiveProcess(lcid)
;based on the input i get perform an operation perform an operation here
This seems to be working fine. But  the ipc process(in this case "DisplaySchematicTree" controls the virtuoso session and i cannot peform any operations on my Cadence database.
Can somebody share there experience on how to solve this issue.
  • skillUser
    skillUser over 11 years ago
    Hi there,
    you probably want to use ipcBeginProcess() to invoke the external script/process in asynchronous mode.
    Take a look at Solution Article 11789648.
    Hopefully this will help you.
    Best regards,
    Lawrence.
    Also ipcSkillProcess supports asynchronous mode.
  • skillseeker
    Thanks Lawrence will try this example and will let you know
  • skillseeker
    Thanks Andrew. Are you saying that i could use ipcSkillProcess the same way as ipcBeginProcess as Lawrence suggests.
    Yes - essentially both ipcBeginProcess and ipcSkillProcess support providing a callback function for stdout, stderr and program exit - which essentially means that as soon as output is produced, that SKILL callback gets asynchronously called. This means you don't necessarily need to have the blocking behaviour that you're having with your current implementation.
  • skillseeker
    Thanks. Working for me great now.
