  3. printself and indention
  • Views 16420
theopaone
theopaone over 11 years ago
I am using printself to pretty print an object with a slot that is a list of other objects with their own printself method. When these print out, all the data starts from the left margin, the nested object descriptions are not indented like pretty printing. I am looking for a way to print the nested sub elements indented (and their nested elements indented from them, etc.)
Ted
    Ted,
    You'll probably need to keep a global variable which gets incremented as it enters the printself method, and decrements as it exits - and then as each sub-instance gets processed within the printself it will further increment and decrement. Something like that...
  • theopaone
    Unfortunately, I was afraid of that. I tried to pass in an extra variable (assuming an @rest argument to the printSelf method) but that did not work. I hate global variables so I won't worry about it.
    Andrew, I hope your holidays were great and your family is doing well. I'm looking forward to 2015 and what happens next.
    Ted
    Hi Ted,
    I had a bit of a play with this and it can be done without using the dreaded global variables by using lexical scoping instead. The example below is not perfect (not 100% happy about how I handle carriage returns to make it prettier), but the idea is OK, I think:
    /* hierObj.ils
    Author     A.D.Beckett
    Language   SKILL
    Date       Jan 02, 2015
    Modified
    By
    Example of printself methods on a hierarchical object
    which use a lexically scoped variable to keep track
    of the indent level
    (defclass topThing ()
       (subThings @reader CCFgetThings @writer CCFsetThings @initarg subThings @initform nil)
    (defclass subThing ()
       (color @reader CCFgetColor @writer CCFsetColor @initarg color)
    (setq top
          (makeInstance 'topThing
                        ?subThings (list
                                     (makeInstance 'subThing
                                                   ?color "red"
                                                   ?subThings
                                                   (list
        ?color "green")
        ?color "blue")
                                                   ?color "yellow"
                                                   ?subThings
                                                   (list
        ?color "cyan")
        ?color "magenta")
    (let ((indent 0))
      (defmethod printself ((obj topThing))
        (letseq ((subThings (CCFgetThings obj)))
                (prog2
                  (setq indent (plus indent 2))
                  (if subThings
                    ; then
                    (sprintf nil "#{instance of topThing:%L}:\n%s"
                             (callNextMethod obj)
                             (buildString (mapcar 'printself subThings) "\n")
                    ; else
                    (sprintf nil "#{instance of topThing:%L}"
                  (setq indent (difference indent 2))
      (defmethod printself ((obj subThing))
        (letseq ((format (sprintf nil "%%%ds" indent))
                 (indentStr (sprintf nil format ""))
                (prog2
                  (if subThings
                    ; then
                    (sprintf nil "%s#{instance of subThing:%L (%Y)}:\n%s"
                             indentStr
                             (CCFgetColor obj)
                    ; else
                    (sprintf nil "%s#{instance of subThing:%L (%Y)}"
                             indentStr
                             (CCFgetColor obj)
    If you load this file and then look at the variable top you get:
    ILS-<2> top
    #{instance of topThing:"stdobj@0x8942060"}:
      #{instance of subThing:"stdobj@0x8942030" (red)}:
        #{instance of subThing:"stdobj@0x8942018" (green)}
        #{instance of subThing:"stdobj@0x8942024" (blue)}
      #{instance of subThing:"stdobj@0x8942054" (yellow)}:
        #{instance of subThing:"stdobj@0x894203c" (cyan)}
        #{instance of subThing:"stdobj@0x8942048" (magenta)}
  • theopaone
    Great solution. Thanks Andrew. Happy New Year.
    Ted
