  3. Get value of component by SKILL code
  • Views 14652
DHung
DHung over 11 years ago
Dear All,
When select a component on drawing then choose menu Display/Element, i can see value of component  on Show Element  window as below:
Properties attached to component definition     TOL               = 10     VALUE             = .01UF
How i get value of component (0.01UF) by using skill code
Hung
Best regards,
Hung
    Hung, what tool are you talking about? It doesn't sound like Virtuoso from your description so I suspect that this may be in the wrong forum. I can move it if it is in the wrong place. Regards, Andrew
