  3. Error Count is not updated in the CheckAndSave Report G...
  • Views 15095
Error Count is not updated in the CheckAndSave Report GUI
Manikk0501
Manikk0501 over 11 years ago
Hi All,
            I wrote a SKILL script to check the values of Device CDF parameter. If it is different from the required value, it should flag error. Script is working fine if I run it standalone .It is creating marker on the devices which are failing the check. I added this subroutine as a PostTrigger to CheckAndSave function using SchRegPostCheckTrigger(). Now, marker is created on the error devices and it is highlighted. But the GUI which shows the final error summary after CheckAndSave does not count the errors identified by the Trigger Function. How to resolve this isse?
Thanks and Regards,
Manikandan Kuzandhaivelu
    Hi Manikandan,
    You have to call  schUpdateUserSRCErrorAndWarn(newErrs newWarns) from your trigger function to tell it about the new errors and warnings.
    Alternatively, there is a new mechanism in IC615 onwards where you can implement a check in a way that it appears on the rule check form, you can change the severity like with other rules, and there's a facility to add markers on the objects for you and take care of the counts. It's much cleaner...
    Here's an example:
    /* abExampleSchematicCheckNew.ils
    Author     A.D.Beckett
    Language   SKILL
    Date       Oct 28, 2011
    Modified
    By
    This is a reimplementation of some of the checks in abExampleSchematicCheck.ils
    but taking advantage of the new interface in IC615 to register checks with
    the system. As a result it is much simpler, and does not have to take care
    of creating marker objects itself; also gives the user the ability to override
    the check, or change the severity if needed.
    To register, call:
    abRegExampleSchematicCheckNew("Your Customer Name")
    (with no arguments, it just calls the rule group "Customer")
    SCCS Info: @(#) abExampleSchematicCheckNew.ils 10/28/11.10:55:00 1.1
    ; The let is to create a lexical scope, so that there can be
    ; private functions which are used for some of the implementation
    let(()
        *  abRegExampleSchematicCheckNew([?customerName "Customer"])   *
        * PUBLIC GLOBAL function used to register the new check group  *
        * and any specific check - in this case an example of a naming *
        *                         convention.                          *
        defglobalfun(abRegExampleSchematicCheckNew (@optional (customerName "Customer"))
            ; This registers a new tab on Check->Rules Setup
            schRegisterCheckGroup(
                ?name concat(customerName)
                ?description strcat(customerName " checks")
            ; This registers the specific rule and default severity
            schRegisterCheckRule(
                ?title "Naming conventions"
                ?name 'namingConventions
                ?groupName concat(customerName)
                ?severity 'error
                ?checkCB checkNamingConventions
        *               checkNamingConventions(cv ruleObject)                *
        * INTERNAL function used to actually implement the naming convention *
        *                               check.                               *
        defun(checkNamingConventions (cv ruleObject)
            let((obj label netTable signals sigTable)
                ; Check that terminal names are in upper case
                foreach(term cv~>terminals
                    unless(term~>name==upperCase(term~>name)
                        ; Place the marker on the first pin - no need to
                        ; put it on every pin if there are multiple pins
                        obj=car(term~>pins~>fig) || cv
                        schReportCheckFailure(
                            ?object obj
                            ?checkRule ruleObject
                            ?short "Terminals not upper case"
                            ?message
                                sprintf(nil "Terminals must be in upper case: %s"
                                    term~>name
                    ) ; unless
                ) ; foreach
                ; Check for internal nets which have a lower case name
                foreach(net cv~>nets
                    ; Only worry about nets which have a label
                    label=car(exists(fig net~>figs fig~>objType=="label"))
                    when(label
                        when(exists(sig net~>signals
                            ; Check that the signal is not part of a
                            ; terminal, and is not in lowercase
                            !sig~>memTerms && sig~>name!=lowerCase(sig~>name))
                                ?object label
                                ?short "Internal nets not lower case"
                                ?message
                                    sprintf(nil "Internal net names must be in lower case: %s"
                                        net~>name
                        ) ; when there is a lower internal net name on net
                    ) ; when there's a label
                ) ; foreach
                ; Check for any nets which only differ in case
                ; record all the signals together in a table indexed by
                ; the flattened case. Then use a table to record all
                ; member nets which have a mixed-case problem
                sigTable=makeTable('sigTable nil)
                netTable=makeTable('netTable nil)
                foreach(sig cv~>signals
                    sigTable[lowerCase(sig~>name)]=
                        cons(sig sigTable[lowerCase(sig~>name)])
                ) ; foreach
                foreach(tableEntry sigTable
                    signals=sigTable[tableEntry]
                    ; If there was more than one signal with the
                    ; same flattened case, then there's
                    ; a mixed name problem. Record the member nets
                    ; in a table (to avoid duplication)
                    when(cdr(signals)
                        foreach(sig signals
                            foreach(memNet sig~>memNets
                                netTable[car(memNet)]=signals
                            ) ; foreach memNet
                        ) ; foreach sig
                    ) ; when
                ) ; foreach
                foreach(net netTable
                    ; Find something suitable to put the marker on
                    cond(
                        ; Use the pin if there is one
                        (net~>term~>pins
                            obj=car(net~>term~>pins~>fig)
                        ; Otherwise use the label
                        (obj=car(
                            exists(shape net~>figs
                                shape~>objType=="label"))
                            t
                        ; Next try a wire
                        (obj=car(
                                    shape~>objType=="line" ||
                                    shape~>objType=="path")
                            t
                        ; Finally, if nothing else, use the cellView
                        (t
                            obj=cv
                    ) ; cond
                        ?object obj
                        ?short "Net differing only in case"
                        ?message
                            sprintf(nil
                                "Net %L cannot differ only in case from others: %L"
                                net~>name
                                netTable[net]~>name
                ) ; foreach
            ) ; let
        ) ; defun checkNamingConventions
    Kind Regards,
  • Manikk0501
    Thank you Very much Andrew
