  3. editing layout in batch mode
  • Subscribers 150
  • Views 16998
ArKa01
ArKa01 over 11 years ago
Hi all,
There is simple change i need to do in all the layouts of a library. I have written a small skill script to do that change.
What I now do is open each cell and execute the script.
Is there any way I can do this in batch mode so that all the cells get changed in one run of the script?
I use IC 6.1.6-64b.500.6
Arshad
  • theopaone
    theopaone over 11 years ago
    Is this a one time thing or will you be doing this repeatedly? If it is a 1 time, you could manually start the procedure in an interactive Virtuoso session, that is easier than trying to do a true batch function as would be called from a make script as you can enter the correct arguments to the function manually.
    You would need to write a procedure which opens each cellView in the library, executes your editing function, saves the data and purges VM.
    foreach( cell ddGetObj( libName )~>cells
    when(ddGetObj( libName cell~>name "layout")
    cv = dbOpenCellViewByType( ... "a") ;; fill in the arguments for lib, cell and view
    DoYourThing(cv)
    dbSave(cv)
    dbClose(cv)
  • ArKa01
    Thanks. This works fine.
