  3. How to do a function call when launch leHiCreateInst() command...
  • Views 1963
How to do a function call when launch leHiCreateInst() command , then press 'Hide' or 'Cancel' button ?
Charley Chen
Charley Chen over 11 years ago
Hi All ,
How to do a function call (e.g. myfun()) when launch leHiCreateInst() command , then press 'Hide' or 'Cancel' button ?
procedure( myfun()
);pro
Thank you,
Charley
  • dmay
    dmay over 11 years ago
    I'm not sure I fully understand your question. I have a wrapper for the create instance form that populates the library, cellname and viewname. This may help you do what you want. It uses hiRegTimer to make sure the form is defined and cancels the form. It then sets the form settings according to the procedure arguments and invokes leHiCreateInst.
    ;;Fill in form if optional arguments are passed.
    procedure(myCreateInst(@optional (lib nil) (cell nil) (view nil) (instName nil))
        ;In 6.1.6, leCreateInstForm is bound and nil at startup
        unless(boundp('leCreateInstForm) && leCreateInstForm
            hiRegTimer("cancelEnterFun(leCreateInstForm)" 1)
            leHiCreateInst()
        leCreateInstForm->libName->value = lib
        leCreateInstForm->cellName->value = cell
        leCreateInstForm->viewName->value = view
        leCreateInstForm->instName->value = instName
        leHiCreateInst()
    myCreateInst("mylibname" "inv" "layout" "myinst")
    This code could easily be elaborated to get the selected instance in a schematic and populate the form for placing it in the layout.
    Derek
  • Charley Chen
    Hi Derek ,
    Sorry for unclear question and  help.
    I want to do something  'when press  Hide/Cancel button when using  leHiCreateInst() ' ,
    I have tried to use " change form back " command , thought skill command is right , but it doesn't work .
    If it can't  do it , I will use another solution to try.
    Thank you for help
    Charley
  • dmay
    If you use a wrapper script like I provided, you can simply add a command after the leHiCreateInst() command. This will run after you cancel the form. I'm not sure how you would trap the "Hide" button press. There is a big difference between what the buttons do, so you might try to describe what you want and maybe there is an alternative solution.
    Derek
  • Charley Chen
    Hi Derek ,
    I follow your suggestion , it can work.
    Thank you,
    Charley
