  3. install Cadence IC 615 on CentOS 6.2: configure status ...
  • Subscribers 153
  • Views 22228
install Cadence IC 615 on CentOS 6.2: configure status failed
Duy Hien
Duy Hien over 11 years ago
Hi everyone,
I have install Cadence IC Hotfix_IC06.15.171 on my computer: Linux CentOS 6.2 32 bit. But it seem that the Cadence IC does not support for Linux CentOS 6.2 version. Install Scape can install the Cadence but cannot configure. Please take a look at the screenshot and give me advices.
By the way, I would like to ask one more question: I am going to install Cadence IC 5.1.41 and IC 6.1.5 in same computer. Which operating system I should install?
Thank you.
  • theopaone
    theopaone over 11 years ago
    I've never gotten Vrituoso to configure on Centos.  I make sure that the tools directory link is created and I can run Virtuoso.
    I have some trouble with text in the CIW and the SKILL IDE but I have not debugged that as it is not a show stopping issue.
    Ted
    If you don't configure the IC installation, it's typically not too critical. Normally when you configure you'd get a terminal window appear. Perhaps you can try:
    cd <ICinstDir> # the one you just installed
    sh installData/IC616_lnx86/batch_configure.sh
    Note however that CentOS is not a supported OS for any release. See
  • Duy Hien
    Thank Ted and Mr. Beckett.
  • venkat379
    venkat379 over 11 years ago
    I had the same problem for CentOS 6.6. It occurs because xterm is not installed.
    yum install xterm
    solved this problem
  • PankajPal
    PankajPal over 6 years ago in reply to Andrew Beckett
    Its helpful, issue has been solved.
