  3. What's the difference between add a device manually and...
  • Views 7414
What's the difference between add a device manually and dbCreateInst? It caused formInitProc failed ..
ArthurLinMTK
ArthurLinMTK over 11 years ago
Dear Andrew:
The most callback work well after I create the instance by dbCreateInst, but when I created the cell with formInitProc, it got the error message - Can't modify attributes of effective CDF parameters, then I can't trigger the callback normally.
I've tried call the function first,as PasCdfFormInit(cdfgData) , and I got the error message "Can't modify attributes of effective CDF parameters"
But if I create the instance manually, the formInitProc function could be run normally, so I think there are some functions be trigger when we add the instance and select to open a CDF form.
What should I do to (after dbCreateInst and before call formInitProc) to make the formInitProc run just like we add an instance and 'q' it manually?  Thanks a lot..
Best Regard,
Arthur
  • ArthurLinMTK
    PS. can't trigger the callback normally means I got "*Error* PasCdfCommitValue:failed to find valid initialization data", thanks.
    Arthur,
    Are you using abInvokeCdfCallbacks or CCSinvokeCdfCallbacks (two different versions of the same code of mine) to trigger the callbacks after creation with dbCreateInst? They have explicit options to help solve this problem, so I'm trying to understand where you're starting from.
    Kind Regards,
  • ArthurLinMTK
    Dear Andrew:
    thanks for your rapidly reply, the code is as following:
    ginstId=dbCreateInst(desId srcId cell_name list(1 1) "R0" 1)
    cdfgData=cdfGetInstCDF(ginstId)
    cdfgForm=cdfgData
    ; I tried to run the FormInitProc , and get Can't modify attributes of effective CDF parameters here
    pasCdfFormInit(cdfgData)
    paramId=cdfFindParamByName(cdfgData "w")
    paramId->value="10u"
    if(paramId->callback then
        evalstring(sprintf(nil "%s" paramId->callback))
    ; then I got *Error* PasCdfCommitValue:failed to find valid initialization data here
    Thank you :)
    Arthur
  • ArthurLinMTK
    Dear Andrew:
    I just tried "abInvokeCdfCallbacks" , and I got the same message,
    and I also tried the debug mode, the callback function names are correct but just can not be trigger normally..
    Arthur
    Hi Arthur,
    I got held up replying to your previous reply. In my experiments, I saw the same problem - but the problem went away if I didn't set cdfgForm (or rather set it to nil). I think having it set to the instance CDF causes problems.
    In abInvokeCdfCallbacks then this wouldn't normally get set  - it usually sets it to nil, unless you pass ?setCdfgForm on abInvokeObjCdfCallbacks. In the version of the code I'm looking at, abInvokeInstCdfCallbacks explicitly sets ?setCdfgForm to nil if instance CDF is being used - so you would do:
    abInvokeInstCdfCallbacks(instId ?callInitProc t ?useInstCDF t)
    and that should work.
  • ArthurLinMTK
    Dear Andrew:
    It works well, thanks you~  You're really the best SKILL programer in the world!
    Thanks again and have a nice day :D
    Best Regards,
    Arthur
