  3. Drop-down menu disappears from schematic window, moving...
  • Replies 7
  • Views 19368
Drop-down menu disappears from schematic window, moving into layout window when VXL is launched
DannyR
DannyR over 11 years ago
A custom Drop Down menu, skill based, for Virtuoso is showing OK when launching Layout or Schematic windows individually. When VXL is launched from schematic window the Drop Down menu disappears from the schematics window and moves to  the layout window. Upon loading Virtuoso I am loading Triggers.il file as shown below.
Any tip why will be greatly apperciated...
Danny
; LAYOUT Triggers
 procedure(DRSetups(args)
  leSetObjectSelectable("Blockages" nil)
  leSetObjectVisible("Blockages" nil)
  leSetObjectSelectable("Boundaries" nil)
  leSetObjectVisible("Boundaries" nil)
;  leSetObjectSelectable("ruler" nil)
;  leSetObjectVisible("ruler" nil)
;  leSetObjectSelectable("Markers" nil)
;  leSetObjectVisible("Markers" nil)
  ; Turn on all Valid Layer
  leSetAllLayerValid(t)
  ; CAD Utilities
  ; Layout
  UtilitiesMenu()
 ); procedure
;  Schematic Triggers
procedure(schSetups(args)
  ; CAD Utilities
  schUtilitiesMenu()
 ); procedure
;; create a user postinstall trigger that automatically setup
deRegUserTriggers("maskLayout" nil nil 'DRSetups)
deRegUserTriggers("maskLayoutXL" nil nil 'DRSetups)
deRegUserTriggers("maskLayoutGXL" nil nil 'DRSetups)
deRegUserTriggers("schematic" nil nil 'schSetups)
deRegUserTriggers("schematicXL" nil nil 'schSetups)
;;; VXL 6.1.6
    Danny,
    Two problems:
    1. Menus should be added via user menu trigger, not the user post-install trigger. This is the second argument to deRegUserTriggers. The idea is that the user menu trigger returns a list of pulldown menus, and "DE" takes care of adding them into the window. This is far more reliable than doing it via the post-install trigger
    2. You didn't provide the code for UtilitiesMenu() or schUtilitiesMenu(), and this is highly likely to be where the problem is. My guess is that these functions use hiGetCurrentWindow() to determine the window to insert the menus into - and that may not be the correct window when you are starting XL - because it is opening a second editor window. Again, this wouldn't be a problem if it was done using the user menu trigger approach (or even if the window was retrieved from args->window - although you really should use the user menu trigger approach)
  • DannyR
    Thanks for the advice.  Below please find the code for the UtilitiesMenu() and schUtilitiesMenu(). Both code modules are loading few skill files. You are correct. In both scripts there is a use of hiGetCurrentWindow()  function.
    Could you please provide a short example of better usage of the Trigger function? 'deRegUserTriggers("maskLayout" nil nil 'DRSetups)' so this issue will be solved?
    Thanks for your time and help!
    Danny
    ; Description
    ; SKILL utilities
    ; Loading sub-programs
    ; Load Triggers
    ; LAYOUT an d Schematic
    load "/home/skill/Triggers.il"
    printf("Loading: Layout and Schematic Triggers...\n")
    ; Zoom to Coordinates
    load "/home/skill/zoomToCoords.il"
    printf("Loading: zoomToCoords...\n")
    ; Put on GRID
    load "/home/skill/putOnGrid.il"
    printf("Loading: putOnGrid...\n")
    ; Loading Schematic Menu
    load "/home/skill/schMenu.il"
    printf("Loading: Schematic Menu...\n")
    procedure( UtilitiesMenu()
    graphicsWin=hiGetCurrentWindow()
    ; If pull down menu does not exist, create it
    ; PullDown menu Creation
    utilMenuItemOne=hiCreateMenuItem(
            ?name           'utilMenuItemOne
            ?itemText       "Zoom to Coords"
            ?callback       "zoomToPoint()"
    utilMenuItemTwo=hiCreateMenuItem(
            ?name           'utilMenuItemTwo
            ?itemText       "Mark Coords"
            ?callback       "zoomGUI()"
    utilMenuItemThree=hiCreateMenuItem(
            ?name           'utilMenuItemThree
            ?itemText       "Put on GRID"
            ?callback       "CCSputOnGrid()"
    hiCreatePulldownMenu(
            'utilitiesPulldownMenu
            "Utilities"
               list(
                hiCreateSliderMenuItem(
                        ?name 'CCSsliderMenuItem1
                        ?itemText "28nm"
                        ?subMenu
                            'CCSsubMenu
                  list(
                    util28SubMenuOne
                    util28SubMenuTwo
                    util28SubMenuThree
                   ) ; CreatePullDownMenu of Sub Menu
                ) ; Slider
                        ?name 'CCSsliderMenuItem2
                        ?itemText "180nm"
                        ?subMenu
                            'CCSsubMenu
                  list(
                    util180SubMenuOne
                    util180SubMenuTwo
                ) ; Slider
                     utilMenuItemOne
                     utilMenuItemTwo
                     utilMenuItemThree
              hiInsertBannerMenu( graphicsWin utilitiesPulldownMenu hiGetNumMenus(graphicsWin))
     ; ) ; End of if exist 'utilitiesPulldownMenu
    ) ; End of procedure( UtilitiesMenu()
    schMenu.il
    ; NET Hierarchy
    load "/home/skill/schHierNetinfo.il"
    printf("Loading: NET Hierarchy...\n")
    ; Specific NET
    load "/home/skill/schNetInfo.il"
    printf("Loading: Specific NET information...\n")
    ; Hierarchy Tree
    load "/home/skill/schTree.il"
    printf("Loading: Hierarchy Tree...\n")
    procedure( schUtilitiesMenu()
    SCHutilMenuItemOne=hiCreateMenuItem(
            ?name           'SCHutilMenuItemOne
            ?itemText       "NET Information"
            ?callback       "schSpecificNetApp()"
    SCHutilMenuItemTwo=hiCreateMenuItem(
            ?name           'SCHutilMenuItemTwo
            ?itemText       "NET Hierarchical Information"
            ?callback       "schNetApp()"
    sep1=hiCreateSeparatorMenuItem(?name 'sep1)
    SCHutilMenuItemThree=hiCreateMenuItem(
            ?name           'SCHutilMenuItemThree
            ?itemText       "Hierarchy Tree"
            ?callback       "CCShiSchTree()"
            'SCHutilitiesPulldownMenu
            "Schematic Utilities"
                  list(
                     SCHutilMenuItemOne
                     SCHutilMenuItemTwo
                     sep1
              hiInsertBannerMenu( graphicsWin SCHutilitiesPulldownMenu hiGetNumMenus(graphicsWin))
     ; ) ; End of if exist 'SCHutilitiesPulldownMenu
    ) ; End of procedure( schUtilitiesMenu()
  • DannyR
    I found an example that you provided here which helped me solving the issue. Everything seems to work OK since I cancelled the menu insertion as you suggested. (The Design Editor infrastructure takes care of this topic.)
    Yet, there is still one more question please: (For the perfectionism's sake...)
    If I start by reading schematic and then launching XL from within that schematic window, it creates all menus OK in the schematic and layout windows, but gives me this one message in the CIW:
    *WARNING* __deMakeBannerMenus ("schematicXL"), duplicate menu(s) removed
    I assume that this is due to the fact that the Drop-Down menu is already exist in the initial schematic window.
    Is there any way to identify the menu's existence and avoid this warning?
    Thanks!
    Danny
    Danny,
    Please post your code. I tried a simple example and don't see this behaviour.
  • DannyR
    Here is the code. Based on your example, I removed the use of  hiGetCurrentWindow() and everything is working fine. The menus do not duplicate anymore and properly show on the schematic and layout windows.
    The only question is when I start with opening a schematic window and then launch VXL from it, it gives me this one line in the CIW:
    *WARNING* __deMakeBannerMenus ("schematicXL"), duplicate menu(s) removed.
    And I was wondering if I can prevent this line.
    Thanks!
    Danny
    ; Load Triggers
    ; Mark Coords
    load "/home/skill/markCoords.il"
    printf("Loading: markCoords...\n")
    ; Put on GRID
    load "/home/skill/DRputOnGrid.il"
    printf("Loading: DRputOnGrid...\n")
    procedure( UtilitiesMenu(args)
    list(hiCreatePulldownMenu(
     "Layout Utilities"
        list(
                        ?itemText "28nm"
                        ?subMenu
                            'CCSsubMenu
                  list(
                    util28SubMenuOne
                    util28SubMenuTwo
                    util28SubMenuThree
                ) ; Slider
                        ?itemText "180nm"
                        ?subMenu
                            'CCSsubMenu
                  list(
                    util180SubMenuOne
                    util180SubMenuTwo
                ) ; Slider
                     utilMenuItemOne
                     utilMenuItemTwo
                     utilMenuItemThree
    ) ; End of procedure - UtilitiesMenu()
    deRegUserTriggers("maskLayout" nil 'UtilitiesMenu)
    deRegUserTriggers("maskLayoutXL" nil 'UtilitiesMenu)
    deRegUserTriggers("maskLayoutGXL" nil 'UtilitiesMenu)
    schMenu.il
    ; NET Hierarchy
    ; Specific NET
    ; Hierarchy Tree
    procedure( schUtilitiesMenu(args)
                  list(
                     SCHutilMenuItemOne
                     SCHutilMenuItemTwo
    deRegUserTriggers("schematic" nil 'schUtilitiesMenu)
    deRegUserTriggers("schematicXL" nil 'schUtilitiesMenu)
    Danny,
    I've worked out the problem. First of all, it seems that registering the trigger for Schematic XL isn't strictly necessary - it calls the Schematic L trigger anyway and retrieves the menus for that. So the function to retrieve the schematic menus gets called twice.
    Now this in itself isn't a major problem, unless you always redefine the menu. In my case I had code around it to prevent it unnecessarily recreating the menu if it had already been created - and that stops the problem from occurring too. So changing your code to:
    ; changed to only create it the first time
    unless(boundp('SCHutilitiesPulldownMenu)
                  list(
                     SCHutilMenuItemOne
                     SCHutilMenuItemTwo
    list(SCHutilitiesPulldownMenu)
    This should fix it too.
  • DannyR
    Problem solved...
    I appreciate your prompt help Andrew!
    Many Thanks,
    Danny
