  3. How to use 'ddSyncWithForm()' inside a TabField?
  • Views 1026
Manikk0501
Manikk0501 over 11 years ago
                        I created a SKILL GUI containing two Tabs. I want to add 'ddSyncWithForm()' as a callback to one of Button Widget i created. Anyone tried this before? . If so, can you please direct me how can i do this
Thanks and Regards,
Manikandan Kuzandhaivelu
    Hi Manikandan,
    The trick is to pass the tab page as the form argument to ddsSyncWithForm. For example, in this code:
    procedure( CCStabFormCreate()
     let((
           ( xWidth  330 )
           ( yDelta  30 )
           ( prompt  126 )
           LayoutLib LayoutCell LayoutView Reason LayoutBrowse
           tabfield1 tabfield2 tabField
         LayoutLib=
          hiCreateStringField(
            ?name     'LayoutLib
            ?prompt      "Library"
            ?value    ""
          ) ; hiCreateStringField
        LayoutCell=
            ?name     'LayoutCell
            ?prompt      "Cell"
            ?value    ""
        LayoutView=
            ?name     'LayoutView
            ?prompt      "View"
            ?value    ""
        Reason=
            ?name     'Reason
            ?prompt      "Reason"
            ?value    ""
        LayoutBrowse=
          hiCreateButtonBoxField(
            ?name     'LayoutBrowse
            ?choices  list( "Browse" )
            ?callback
            ;list( "ddsSyncWithForm( CCStabForm 'browse 'LayoutLib 'LayoutCell 'LayoutView )" )
            list( "ddsSyncWithForm( eval(CCStabForm->tabField->page1) 'browse 'LayoutLib 'LayoutCell 'LayoutView )" )
            ?prompt      " "
          ) ; hiCreateButtonBoxField
        tabfield1 = list(
                       list(LayoutBrowse  xWidth/2:1*yDelta  xWidth/2 :yDelta-10  prompt/2        )
                       list(LayoutLib           10:2*yDelta  xWidth-20:yDelta      prompt/2        )
                       list(LayoutCell          10:3*yDelta  xWidth-20:yDelta      prompt/2        )
                       list(LayoutView          10:4*yDelta  xWidth-20:yDelta      prompt/2        )
        tabfield2 = list(
                       list(Reason              10:5*yDelta                xWidth-20:yDelta  prompt/2        )
        tabField = hiCreateTabField(
              ?name                                'tabField
              ?notebookStyle nil
              ?pageScroller        nil
              ?tabPlacement        'top
              ?tabs                                list("first" "second")
              ?fields                        list(tabfield1 tabfield2)
              ?value                        1
          hiCreateAppForm(
            ?name                    'CCStabForm
            ?fields                 list(list(tabField 0:0 xWidth+5:13*yDelta+15 0))
            ?initialSize list( xWidth+5 13*yDelta+15)
         hiDisplayForm(CCStabForm)
    Note that this example is a little peculiar, because it has the same lib/cell/view fields on both the first two pages. However, see the callback for the button - you should get the idea from this.
