  3. hiCreateReportField: How would I pass a value stored in...
  • Views 16490
hiCreateReportField: How would I pass a value stored in a variable to choices? list
BasavarajH
BasavarajH over 11 years ago
Hi there,
When I am trying to use the variables like;
a="drawing"
b="100"
form~>handle~>choices=list(list(a b))   >>doesnt work
form~>handle~>choices=list(list("drawing"  "100"))   >>this works
in the choices columns the same values are not reflected on the reportField form.
Please help with me with this as I have a requirement to display many rows on the ReportField where all the rows content is stored in different variables post some processing code.
Thanks.
    This works for me, both when specifying ?choices and also using the approach you are using above. I suggest you give a complete code example that doesn't work as then it might be possible to see what you're doing wrong.
  • BasavarajH
    new=hiCreateReportField(
    ?name 'newReport
    ?title "New Report Field"
    ?selectMode 'multiple
    ?headers list(
               list("Column1" 50 'left)
               list("Column2" 200 'left)
    ?callback 'reportCB
    newQuerryForm =  hiCreateForm('newQuerryForm "QuerrySel" nil list( list(,new 0:0 655:200 1)))
    hiDisplayForm(newQuerryForm)
    newQuerryForm~>newReport~>choices=list(list("Hello" "Hi"))            > This works fine
    num=100
    newQuerryForm~>newReport~>choices=list(list(num "Hi"))                 > Now column1 remains empty(nothing displayed)
    This is because you didn't provide a list of list of strings. The first entry in the sublist was an integer, not a string.
    If you do:
    newQuerryForm~>newReport~>choices=list(list(sprintf(nil "%d" num) "Hi"))
    then it works fine.
