  3. Creating lines between 2 points while using enterPoints...
  • Views 14984
Creating lines between 2 points while using enterPoints function
Adi Szeskin
Adi Szeskin over 11 years ago
i wrote the following procedure in order to save a "polygon" points in a file.... the main issue i have here is that i want that between each mouse click ill see a flight line between the last point to the current point or to the mouse. is it possible?
procedure( GetCursorCoord( @key (numbOfPoints 20) (fileName "CursorCoord.log"))
let((messages pt fp)
; Create a message to prompts
for( i 1 numbOfPoints
messages = cons(sprintf(nil "Enter %d point" i) messages)
messages = cons(sprintf(nil "Enter the next point") messages)
if( !(fp = outfile(fileName)) then
warn("Failed to open file %L\n" fileName)
; Get enter points from user
points = enterPoints(
?prompts reverse(messages)
?addPointProc ???
?doneProc "test_end"
; Write the coordinate to a file
printf("Finished writing file")
close(fp)
);let
);proc
procedure( test_end( window done points )
let(()
foreach( pt points
fprintf(fp "%L,%L," nth(0 pt) nth(1 pt)))
fprintf(fp "\n")
    Maybe you want to use enterLine() rather than enterPoints()?
  • Adi Szeskin
    Thanks Andrew :).
