  3. rod PCELL (Metal with slot)
  • Subscribers 152
  • Views 19124
Avadh
Avadh over 11 years ago
I am new to pcell and trying to create a rectangle metal with slots. (by provinding size of slot, x and y enclosure etc..)
I can easily do it using Layout editor by drawing a rectangle and by using Create-> Slot
How can I create slot when I used rodCreateRect to create a rectangle and want to use same kind of options available in Create->Slot to create slot in pcells.
Any example skill file will be appreciated.
    That rather depends on whether your slots are defined as a shape on a layer (which will be used to cut the holes in a layer processing step downstream) or whether you really want holes.
    I don't have any code to hand  to do this anyway, but maybe somebody else does - I'm just suggesting you give a few more details on precisely what  you're looking for.
  • Avadh
    Andrew - Thanks for your response.
    I really want holes. I want to create a met5 rectangle of 50x50um and cut holes in it to reduce stress. I want to make it a pcell as user will be able to change rectangle size by varying w and l
    Avadh
    Avadh,
    Something like:
    w=50
    l=50
    space=8
    offset=5
    slotW=1
    slotL=1
    shape=rodCreateRect(
      ?cvId pcCellView
      ?layer "Metal1"
      ?width w
      ?length l
      ?subRectArray
        list(
          list(
            ?layer "y0"
            ?width slotW
            ?length slotL
            ?spaceX space
            ?spaceY space
            ?lowerLeftOffsetX offset
            ?lowerLeftOffsetY offset
            ?upperRightOffsetX -offset
            ?upperRightOffsetY -offset
    dbLayerAndNot(pcCellView "Metal1" list(shape~>dbId) shape~>subShapes)
    ; you might need to collect the dbId and subShapes, unname the rod object, and delete them
    ; individually - can't remember whether deleting the master object is sufficient in a pcell
    dbDeleteObject(shape~>dbId)
  • theopaone
    theopaone over 11 years ago
    Another way is to use rodCreatePath with offset rectangles and subPaths to draw metal, leaving spaces between the slot filler metal. There is some up front calculation to break down the width into metal/slot/metal/slot/metal... steps and make sure that there is sufficient metal width on the two outer edges. I would calculate the exterior path widths and then calculate where the slots would need to be required such that I don't create a wire that is too skinny. Then draw the path with rodCreatePath. It will work with orthogonal paths only.
    When digitizing the path, I use enterPath with a full width path and then pass the points to the pcell.
  • AlessandraT
    AlessandraT over 6 years ago in reply to theopaone
    Hi All,
    I need to have a slot with diagonal corners. What do you suggest to do in this case?
    Thanks.
    Alessandra
    Andrew Beckett over 6 years ago in reply to AlessandraT
    As outlined in the forum guidelines, please don't post on the end of an old thread with a new topic such as this (even if it's somewhat related to the old thread).
    So please start a new thread, with pictures showing what you actually want to do.
