  3. How can I get a list of expressions/outputs used in ADE...
  • Views 2288
How can I get a list of expressions/outputs used in ADE-XL session
Ron M
Ron M over 11 years ago
I would like to create a form in ADE-XL on which a user will select an expression to be used for certain operation.
How can I get the list of expressions defined on a specific session setup (or a test)?
    Hi Ronen,
    Something like this:
    axlSess=axlGetWindowSession()
    sdb=axlGetMainSetupDB(axlSess)
    foreach(testName cadr(axlGetTests(sdb))
      sevSess=axlGetToolSession(axlSess testName)
      asiSess=sevEnvironment(sevSess)
      printf("Outputs for test %s\n" testName)
      foreach(output asiGetOutputList(asiSess)
        when(output->expression
          printf("  %s : %L\n" output->name||sprintf(nil "%L" output->expression) output->expression)
    Note that the above shows the expression as the name if there is no name for the output (which is what ADE XL does).
  • Ron M
    Thanks. It works perfectly.
