  3. Assura DRC Error: geomContactCheck() Keyword is unsupported...
  • Views 1495
Assura DRC Error: geomContactCheck() Keyword is unsupported, or operator undefined -- allWithTolerance >>>>>> *WARNING* Failed to build VDB. Cannot submit DRC Run.
Majid Rafei
Majid Rafei over 11 years ago
I am trying to run Assura DRC. My technology file is TSMC130nm, Assura 316, IC5141 USR6. CIW shows the following error:
\o Loading tech rule set file : /home/icic/tsmc130rf/Assura/techRuleSets
\o Compiling rules...
\o
\o function viawithsize redefined
\o function geomSizeAndProc redefined
\e *Error* eval: unbound variable - allWithTolerance
\o error:  geomContactCheck() Keyword is unsupported, or operator undefined -- allWithTolerance.
\o   1031. oddn11_d = geomContactCheck(oddn1_d0 (length == 500) swap (allWithTolerance = 1.0))
\o   1087. oddn21_d = geomContactCheck(oddn2_d0 (length == 500) swap (allWithTolerance = 1.0))
\o   2796. m1dn1l1_d = geomContactCheck(m1dn1l_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   2852. m1dn1h1_d = geomContactCheck(m1dn1h_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   2909. m2dn1l1_d = geomContactCheck(m2dn1l_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   2965. m2dn1h1_d = geomContactCheck(m2dn1h_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   3022. m3dn1l1_d = geomContactCheck(m3dn1l_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   3078. m3dn1h1_d = geomContactCheck(m3dn1h_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   3135. m4dn1l1_d = geomContactCheck(m4dn1l_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   3191. m4dn1h1_d = geomContactCheck(m4dn1h_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   3256. m8dn1l1_d = geomContactCheck(m8dn1l_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   3312. m8dn1h1_d = geomContactCheck(m8dn1h_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   3374. mddn1l1_d = geomContactCheck(mddn1l_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   3430. mddn1h1_d = geomContactCheck(mddn1h_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   3761. srco_viawarn_line_co = geomAndNot(sr_co geomContactCheck(sr_co (length == 0.16) (width == 0.16) swap (allWithTolerance = 1.0)))
\o   3764. srco_viawarn1_line_via1 = geomAndNot(sr_v1 geomContactCheck(sr_v1 (length == 0.19) (width == 0.19) swap (allWithTolerance = 1.0)))
\o   3767. srco_viawarn2_line_via2 = geomAndNot(sr_v2 geomContactCheck(sr_v2 (length == 0.19) (width == 0.19) swap (allWithTolerance = 1.0)))
\o   3770. srco_viawarn3_line_via3 = geomAndNot(sr_v3 geomContactCheck(sr_v3 (length == 0.19) (width == 0.19) swap (allWithTolerance = 1.0)))
\o   3773. srco_viawarn4_line_via4 = geomAndNot(sr_v4 geomContactCheck(sr_v4 (length == 0.19) (width == 0.19) swap (allWithTolerance = 1.0)))
\o   3776. srco_viawarn5_line_via5 = geomAndNot(sr_v5 geomContactCheck(sr_v5 (length == 0.19) (width == 0.19) swap (allWithTolerance = 1.0)))
\o   3779. srco_viawarn6_line_via6 = geomAndNot(sr_v6 geomContactCheck(sr_v6 (length == 0.19) (width == 0.19) swap (allWithTolerance = 1.0)))
\o   3782. srco_viawarn7_line_via7 = geomAndNot(sr_v7 geomContactCheck(sr_v7 (length == 0.36) (width == 0.36) swap (allWithTolerance = 1.0)))
\o   4882. _m5_mmdn1l1_d = geomContactCheck(_m5_mmdn1l_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   4938. _m5_mmdn1h1_d = geomContactCheck(_m5_mmdn1h_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   4994. _m6_mmdn1l1_d = geomContactCheck(_m6_mmdn1l_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   5050. _m6_mmdn1h1_d = geomContactCheck(_m6_mmdn1h_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   5106. _m7_mmdn1l1_d = geomContactCheck(_m7_mmdn1l_d0 (length == 200) swap (allWithTolerance = 1.0))
\o   5162. _m7_mmdn1h1_d = geomContactCheck(_m7_mmdn1h_d0 (length == 200) swap (allWithTolerance = 1.0))
\o Errors exist in the rules file '/home/icic/tsmc130rf/Assura/./drc/assura.drc'.
\w *WARNING* Failed to build VDB. Cannot submit DRC Run.
    Your Assura version is too old. The allWithTolerance option was introduced in ASSURA317 (I believe, because even this is ancient so I can't readily check). The current version of Assura is ASSURA41.
    Kind Regards,
