  3. suppressing "function <functionNameHere> redefined" output...
  • Views 5172
suppressing "function <functionNameHere> redefined" output text
mtwadeCU
mtwadeCU over 11 years ago
I have a procedure that defines a few procedures inside of it (even though I just learned there is no such thing as local functions in SKILL). Everything works fine until I call this procedure from a pcDefinePCell script. I get a message that the pcell generated information, and I can view the information in a temporary file. When I view the file, it just contains the list of functions that were redefined. Is there a way to suppress this output? It causes issues e.g. when you go to compile pcells (flashing yellow x because it interprets it as a pcell eval fail) and stream them out to gds (streamout fails because it thinkgs the pcell eval failed).
Mark
    First of all, there are local procedures in SKILL - you just (to make it simpler) have to do it in SKILL++ mode.
    Are you putting procedure(...) calls within the body of the pcDefinePCell? That doesn't really make sense - pcDefinePCell has to be done in SKILL language mode, rather than SKILL++ language mode - but it can call functions that were defined elsewhere. What I would suggest you do is to create a function that does all the real work (which could have local functions, and be defined in a file with a .ils suffix) and then load that file from the libInit.il (or libInit.ils file) of the library containing the pcell. Then have your:
    pcDefinePCell(
       list(ddGetObj("libName") "cellName" "layout")
         (w ...)
       functionThatDoesAllTheWork(pcCellView w l)
    Nothing will get redefined if you do this - so you won't get the warning messages at run time, and hence no pcell eval failure messages.
    Note you can suppress the message, by doing:
    putd('funcName nil)
    before redefining the procedure/function. However, my guess is that you'd be better served by organising the code differently.
    Of course, this is all guesswork because I've not seen what you're doing!
  • mtwadeCU
    Andrew,
    Thanks for the response!
    My problem seems to be that I'm not using any functions using SKILL++ language mode. So, what I was intending to be local procedures are written as SKILL language mode (.il) and have global scope. Thus, they get redefined every time.
    I implemented things such that the procedure with local procedures is in SKILL++ and just called from SKILL language mode. This seems to fix things and get the behavior I want. Thanks for the suggestion!
    Mark
